1965 Imperial Trans Cable Problem #2095505
06/21/16 09:47 AM
06/21/16 09:47 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Morning,
Got a buddy with 1965 413/727 Imperial. told the pushbutton set-up on the 1965 was a one year only deal.
None of the gears are where they're supposed to be. Reverse is off a selection. Drive is only functional in 2-low.
Park doesn't engage at all, even if you manually move the park lever.........the tires will still move.
What have we missed?
Thanks.
Michael
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2095517
06/21/16 10:04 AM
06/21/16 10:04 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
The adjustment procedure for '65 is different from other years. What procedure did you use to adjust? What caused the problem to start? Perhaps John Kunkel will post his advice.
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2095587
06/21/16 12:16 PM
06/21/16 12:16 PM
moparx Offline
moparx  Offline
if you pm me with your e-mail address, i can scan the factory procedure from my FSM into a pdf file for you.
beer
Re: 1965 Imperial Trans Cable Problem [Re: TooMany62s] #2095771
06/21/16 05:48 PM
06/21/16 05:48 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Hey,
Pulled the tranny to have it rebuilt and fix leaks.
Trying to help a friend, lemme see what they've done so far.
email is DLAWD@aol.com
many thanks for responding
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2095790
06/21/16 06:22 PM
06/21/16 06:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By SILVER67
Morning,
No pushbuttons in '65, only column or console shifters. In either case the procedure is as follows:
Remove the lock screw from the cable adjustment wheel and back the wheel off several turns.
1. Have an assistant hold the selector lever firmly in the "1" (Low) position.
2. Hold the control cable centered in its bore in the transmission case, and pull outward on the cable with about two pounds of force to bottom the manual lever in the "Low" detent.
3. While maintaining this pull on the cable, rotate the adjustment wheel clockwise until it just contacts the case squarely.
4. Turn the wheel counterclockwise just enough to make the nearest hole in the wheel line up with the screw hole in the case.
5. Counting this hole as number one, continue turning the wheel counterclockwise until the fifth hole lines up with the screw hole in the case.
6. Push the cable in toward the transmission until the adjustment wheel is tight against the case and install the lock screw, tightening to 75 inch-pounds torque.
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2096081
06/22/16 09:10 AM
06/22/16 09:10 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Once again John Kunkel to the rescue. If it has push buttons it must be '64 or older. And I'm pretty sure the push button cable adjustment procedure is different in '64 compared to '63 and '62.
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2096184
06/22/16 12:33 PM
06/22/16 12:33 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I too thought there was an Imperial only shifter oddity around that year. If it wasn't push buttons in 65 when the rest of the fleet went to lever, was it cable in 66 when the rest went to linkage shift?
Kevin
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2096191
06/22/16 12:51 PM
06/22/16 12:51 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Ok So, we've got Drive ( which won't shift out of first gear ) and Reverse..............no Park.....
Ehhhh, where did we go wrong?
TX ! ! ! ! ! ! ! !
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2096248
06/22/16 02:58 PM
06/22/16 02:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You might have two problems; a faulty governor inside the trans preventing upshifts and misadjusted park cable. The shift cable and the park cable are separate adjustments.
The park cable is actuated by a mechanism at the base of the steering column inside the engine compartment; basically, when the shift lever is moved from Reverse to Park a separate mechanism takes over and actuates the park cable.
To isolate the "no upshift" problem, disconnect the rod that attaches to the transmission lever at the lever and allow the trans lever to come full forward. If it still won't automatically upshift in Drive the problem is internal.
Re: 1965 Imperial Trans Cable Problem [Re: SILVER67] #2096646
06/23/16 09:48 AM
06/23/16 09:48 AM
moparx Offline
moparx  Offline
i scanned and sent the pdf to you yesterday, late morning. that should work along with john's advice.
beer
Re: 1965 Imperial Trans Cable Problem [Re: John_Kunkel] #2096705
06/23/16 12:21 PM
06/23/16 12:21 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Morning,
Thanks for posting this. I saved it so that I can adjust the 65 Franken-transmission
