Ported Indy Intakes #2092551
06/15/16 05:03 PM
06/15/16 05:03 PM
Out West
408strokerdart Offline OP
Out West
Please share some internal pictures of your ported Indy intake manifolds. Will be using the single 4500 for 440-1 245CNC heads. Anything to do differently if running Alky?
Re: Ported Indy Intakes [Re: 408strokerdart] #2092578
06/15/16 05:45 PM
06/15/16 05:45 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
245cc...?????? is a small block head...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Ported Indy Intakes [Re: WHITEDART] #2092657
06/15/16 08:21 PM
06/15/16 08:21 PM
Out West
Out West
Big Block 440-1 heads.
Re: Ported Indy Intakes [Re: 408strokerdart] #2093136
06/16/16 07:27 PM
06/16/16 07:27 PM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
ill try to find an old pic of one I did that worked well correcting distribution without removing length from the runner dividers. if you look straight down the throttle barrels trajectory, you'll see why they bias fuel towards the outer runners...So, I undercut the divider bottoms with about a 3/4" radius then radiused the inner walls to a near point on the outer runner edges...especially on top...never knife edge the leading edges. If no one posts one done 'correctly' here look at the general practices that you will find posted on YBullet in the engine section. Another thing that can be done is give it more plenum via spacer...that will help distribution as well....other than this it is a good manifold.
Re: Ported Indy Intakes [Re: HardcoreB] #2093508
06/17/16 02:07 PM
06/17/16 02:07 PM
Out West
Out West
Yes, I would love to see some pictures of one done right. The port dividers were my biggest question. They are not right the way they are now....that's for sure.
Re: Ported Indy Intakes [Re: HardcoreB] #2093567
06/17/16 04:24 PM
06/17/16 04:24 PM
Australia
P
Project kickin A Offline
P
Australia
I don't know why Indy did this with the runners but I am interested to see also as I'm about to do the same. popcorn
Re: Ported Indy Intakes [Re: 408strokerdart] #2093609
06/17/16 05:49 PM
06/17/16 05:49 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I would also like to see how guys have opened up the transition to the runners. Mine looked like it needed a bunch of opening up especially for 2 1/8 blades, which I did.
Re: Ported Indy Intakes [Re: 408strokerdart] #2094575
06/19/16 07:47 PM
06/19/16 07:47 PM
Australia
P
P
Australia
I started doing mine but my poor old air compressor died... should I be taking more out from the bottom of the runner?
Re: Ported Indy Intakes [Re: 408strokerdart] #2094592
06/19/16 08:33 PM
06/19/16 08:33 PM
AndyF Offline
AndyF  Offline
I think the Super Victor is a better intake to start with.
Re: Ported Indy Intakes [Re: 408strokerdart] #2094648
06/19/16 10:46 PM
06/19/16 10:46 PM
Australia
P
P
Australia
maybe so Andy but many of us don't have the budget to endlessly buy intakes plus being downunder makes for double the cost, we gotta run what we brung or what we can get our hands on at least.
Re: Ported Indy Intakes [Re: AndyF] #2095091
06/20/16 04:43 PM
06/20/16 04:43 PM
Out West
Out West
That looks 1000% better than what I currently have. I guess I will take some before and after pics of mine. Time to make a pile of chips.
Re: Ported Indy Intakes [Re: 408strokerdart] #2095126
06/20/16 05:58 PM
06/20/16 05:58 PM
an8sec70cuda Offline
It looks that good b/c Wilson has already ported that one.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Ported Indy Intakes [Re: an8sec70cuda] #2095213
06/20/16 08:25 PM
06/20/16 08:25 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I thought the Victor bottom end didn't compare to the Indy
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Ported Indy Intakes [Re: 408strokerdart] #2096062
06/22/16 07:19 AM
06/22/16 07:19 AM
Australia
P
P
Australia
ok so here is what Ive done so far, a first up rough attack on the plenum dividers, there was a little casting flash on the plenum floor so hench the buzz around....
Re: Ported Indy Intakes [Re: 408strokerdart] #2096091
06/22/16 09:49 AM
06/22/16 09:49 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
On my 440-1 CNC 345 4500 intake that i ported out it ended up kinda looking like the intake Andy posted as all squared up in there in the plenum and not like the stock Indy with that extra aluminum cloverleaf look. I also took a little more off in the outer 4 runners in the plenum are to help make the plugs look better and more equal, still wanna take a little more off there yet. I only have a couple basic pics but can try in get more stuff is at my garage. I did bring the dividers back some also.
Mopar Performance
Re: Ported Indy Intakes [Re: 408strokerdart] #2096093
06/22/16 09:54 AM
06/22/16 09:54 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: Ported Indy Intakes [Re: 408strokerdart] #2096095
06/22/16 10:00 AM
06/22/16 10:00 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
