Re: Panel Dimmer Switch
[Re: mopar4u]
#2094378
06/19/16 12:37 PM
06/19/16 12:37 PM
RapidRobert
I'd get a can of "contact cleaner" at your electronics store, the spray can with the thin red straw & shoot it with that
[Re: mopar4u]
#2094411
06/19/16 01:35 PM
06/19/16 01:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not designed to be disassembled at all. Since I don't have a switch handy I can't say how easy it'd be to pull apart and clean. But if this is it, Then you ought to be able to take it apart if you are careful and clean it up.
