Am I missing an easier way for this press-on PS pulley?
#2094274
06/19/16 01:53 AM
06/19/16 01:53 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I'm about halfway into pressing a pulley onto a new power steering pump for my 96 Magnum engine. O'Reilly's and the like did not have an installer kit with the correct threads for the 96 PS pump shaft, so I had to use the "tool" that came with the pump.
The "tool" is a bolt, a square nut, a washer, a big thin white plastic washer thing that broke immediately, and a rubber o-ring that is sized to the bolt threads. The instructions made no mention of the o-ring so I have no idea what it's for.
After threading the nut onto the bolt and dropping the washer on, I threaded the bolt down the pump shaft and was able to get the setup to operate as intended - right until the pulley really squared up with the shaft. Then it just wanted to spin the bolt out through the nut.
I was able to get the pulley mostly pressed on the rest of the way (a couple ribs away from being square, about 0.5" of shaft showing on the back)) by looping the drive belt around the pulley and pressing down over the idler while turning the nut, but by then I wasn't able to hold the pulley firmly enough to continue to torque it down. I can't jam up the pulley through the bolt access holes or it will chip.
If the pulley isn't spinning under my improvised belt vise, I'm just backing the bolt out through the nut instead of continuing to spin the nut down the bolt to keep pressing the pulley on.
Is there another nuts-n-bolts way of pressing these things on? Am I supposed to put the o-ring at the very end of the bolt so it stays torqued at the bottom and doesn't just spin out or something?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Am I missing an easier way for this press-on PS pulley?
[Re: mopar4ya]
#2094314
06/19/16 10:08 AM
06/19/16 10:08 AM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
I think you will find the white nylon washer and o-ring are for the power steering hose or the large fitting that is screwed into the pump. As for installing the pulley, first I hope you used some oil on the shaft since you have it started on and it takes a special puller to remove it. Thread the nut all the way on to the bolt, put the steel flat washer on and thread the bolt all the way into the pump. It should go in about 1-1/4 to 1-1/2 inch. Hold the bolt head so it can not turn while turning the nut only clock wise ( looking down at it) pushing the pulley all the way until the pulley hub is flush with the end of the shaft. Sometimes these do go on very hard.
Dan. agreed sometimes they are hard to press on with the "tool" kit they provide. "Everything goes together better wetter"
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
[Re: Secret Chimp]
#2094326
06/19/16 10:39 AM
06/19/16 10:39 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Putting the pulley in a pot of boiling water for a few minutes would have fixed all this.
