Page 5 of 5 1 2 3 4 5
Re: lifter valley plate for trick flows [Re: Jimbo] #2184924
10/28/16 10:22 PM
10/28/16 10:22 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Trying to be helpful... The valley breather is a tough nut to crack. A lot of oil in suspension there. You need a large amount of well thought out baffling to succeed. Also, with any breather, the larger the inner diameter of the exit tube, the lower the velocity. Velocity is the common culprit of oil escaping from breathers.
Re: lifter valley plate for trick flows [Re: Jimbo] #2194471
11/11/16 01:09 AM
11/11/16 01:09 AM
AndyF Offline
AndyF  Offline
I now have solid valley plates for RB blocks. I had a bunch of people ask me to make them so I went ahead and ran a batch. If you want one you can order it from Hughes or Mancini Racing. Part number is AR300A. Don't forget the A on the end. The AR300 is the two piece cover, the 300A is the one piece version.
Re: lifter valley plate for trick flows [Re: Jimbo] #2194601
11/11/16 10:37 AM
11/11/16 10:37 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Looks Great Andy! How did the valley breather work out?
Are the Batwings also available? Standard and/or MW port?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: lifter valley plate for trick flows [Re: Jimbo] #2194754
11/11/16 02:03 PM
11/11/16 02:03 PM
AndyF Offline
AndyF  Offline
I haven't run the engine with the valley breather yet. I'm in the middle of complete engine re-shuffle with my 470 engine turning into two different 470 engines.
I do have batwings on hand in both the std port as well as the MW port size. I haven't tried the MW port size on an engine yet myself but I've sold some to folks who gave me a thumbs up on the fitment. There are a lot of different MW port sizes floating around as well as different gasket sizes so it wasn't a perfect one-size-fits all solution.
Re: lifter valley plate for trick flows [Re: AndyF] #2194778
11/11/16 02:27 PM
11/11/16 02:27 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
It will be interesting to see how the new TF270s will fit into the "MW" port size arena.
Re: lifter valley plate for trick flows [Re: AndyF] #2194785
11/11/16 02:45 PM
11/11/16 02:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
What are "Bat wings" ?
