what a puzzle #2090409
06/12/16 01:22 AM
06/12/16 01:22 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
i found out why 383 was not cranking,it was not getting any fire down to plugs.replace plugs and wires friday and fired up and ran until i turn it off,today back to no fire to plugs,i changed ballast,voltage regulator,coil,nothing,even changed the ignition switch,nothing,something is blocking power to coil,distributor,plugs,but what can it be?i checked power to coil it shows no fire,but i test primary and secondary it check out really strong. i am lost. this is dual point distributor has good ponts and the harness is new.
Re: what a puzzle [Re: moparpro] #2090417
06/12/16 01:41 AM
06/12/16 01:41 AM
Kirkland, Washington
Pacnorthcuda Offline
The first check I would make would be for power to and from the ballast resistor
Re: what a puzzle [Re: Pacnorthcuda] #2090421
06/12/16 01:50 AM
06/12/16 01:50 AM
You're saying it will crank but will not start? if so, unplug the yellow with tracer wire on the "ign" terminal of the starter relay to disable the starter & have a helper hold the ign key to "start" & you under the hood with your meter or a test light see if the brown wire to the coil is getting fire then release the key to "on" and as said see if there is fire/continuity to/thru the ballast (the blue wire ign1 "run" circuit) & on to the coil positive primary terminal.
Re: what a puzzle [Re: RapidRobert] #2090422
06/12/16 01:53 AM
06/12/16 01:53 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
it will crank,but no start.no power to plugs,or power coming out of coil,but coil test good.
Re: what a puzzle [Re: Pacnorthcuda] #2090423
06/12/16 01:56 AM
06/12/16 01:56 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
how do i use the multimeter on that resisitor?
Re: what a puzzle [Re: moparpro] #2090426
06/12/16 02:01 AM
06/12/16 02:01 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Dual resistor ~ 5 ohms across terminals and .5 ohms across the other set. Side to side, not up and down.
Single resistor ~ 1.5 ohms
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: what a puzzle [Re: moparpro] #2090427
06/12/16 02:04 AM
06/12/16 02:04 AM
unplug the 2 wire terminals from it. set meter to lowest ohms scale/touch probes to each ballast terminal. hold em tight for good continuity & let the meter numbers settle (my peeve of digitals). My last 2 terminal "single" ballast I checked was 1.6 ohms
Re: what a puzzle [Re: RapidRobert] #2090493
06/12/16 08:46 AM
06/12/16 08:46 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
thanks
Re: what a puzzle [Re: DARTH V8Я] #2090494
06/12/16 08:46 AM
06/12/16 08:46 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
thanks
Re: what a puzzle [Re: RapidRobert] #2090792
06/12/16 07:09 PM
06/12/16 07:09 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
tested ballast and i got 0.8,anyway to check ignition switch socket?
Re: what a puzzle [Re: moparpro] #2090853
06/12/16 09:16 PM
06/12/16 09:16 PM
pull a batt cable off of its post before grabbing the meter (if using ohms scale). if the ign sw is in the st column seperate the dangling connector halves under the column & see if you have continuity between the hot power in wire (likely red) and the wire for the ign1 ""run" circuit when you turn the key to "on". then hold the key to "start" & see if there is continuity between the red wire and the wire for the ign2 "crank" circuit. www.mymopar.com will likely have the colors for you or you can likely figure it out just by seeing what gets continuity at the connector. First before this you might seperate the bulkhead & do the same procedure, you'll have the power in which is the fusible link coming in from the starter relay and there'll be an out wire for "run" circuit (might be blue) and an out wire for the "crank" circuit which might be brown. if the ign switch is in the dash, take it out and same thing, there will be a power in terminal and an "ign1" stamped terminal for "run" and a stamped "ign2" terminal for "crank", same procedure, looking for the open
Re: what a puzzle [Re: RapidRobert] #2090918
06/12/16 11:04 PM
06/12/16 11:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Bulkhead connections ??? Check for voltage as previously advised.
if no v present, Try jumpering Voltage to the ballast, coil etc.
hit the key. twocents
Re: what a puzzle [Re: moparpro] #2090973
06/13/16 12:20 AM
06/13/16 12:20 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
i went back to check coil positive with key in on pos and it has power coming to coil,i went and checked the ignition switch with key in on pos and i got lights from all the wire except the yellow wire that goes to the starter relay.it is only hot in start position i have figure out a way to keep tester light on wire while cranking to make sure light comes on to show power to relay.
Re: what a puzzle [Re: moparpro] #2090985
06/13/16 12:36 AM
06/13/16 12:36 AM
that yellow wire will only be hot while cranking
Re: what a puzzle [Re: RapidRobert] #2091110
06/13/16 11:11 AM
06/13/16 11:11 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
my points might be open,i have to learn about points,still investigating.
Re: what a puzzle [Re: moparpro] #2091143
06/13/16 12:09 PM
06/13/16 12:09 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
Fuse able link ?
Re: what a puzzle [Re: moparpro] #2091149
06/13/16 12:14 PM
06/13/16 12:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Hook light to neg coil and ground.crank should flash.If not either points are bad or dist inst turning.The pos side of coil should be hot with key on.Points condensor can go bad as can cap and rotor.if it flashes and no spark either coil cap rorot or coile wire.oh yeah no crank is totally different than no start.No crank menas the motor wont turn over at all.Rocky
Chrysler Firepower
Re: what a puzzle [Re: therocks] #2091163
06/13/16 12:28 PM
06/13/16 12:28 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
i checked ignition wires at socket this morning and all connections has power except the yellow wire,it has to be in crank mode before power appears,so i crank motor with light on yellow wire and there is no power coming from that yellow wire in cranking mode,does that mean starter relay is bad?car will turnover but no start. thanks
Re: what a puzzle [Re: dartgame] #2091233
06/13/16 02:58 PM
06/13/16 02:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted By dartgame
Fuse able link ?
If the fuseable link was burnt opened there would be no voltage anywhere except to the main starter post on the starter or starter relay work scope
Re: what a puzzle [Re: moparpro] #2091234
06/13/16 03:00 PM
06/13/16 03:00 PM
if it is turning over there has to already be power from the "st" terminal on the ign sw out to the yellow wire to the "ign" terminal on the starter relay as that is what closes the SR to engage the starter
