Re: what a puzzle
[Re: moparpro]
#2092582
06/15/16 05:50 PM
06/15/16 05:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Pull the cap and look to see if the rotor button inside the cap is still there. If so, ohm out the coil wire, you may have a break in it. I've seen the coil wire do that and have enough juice to appear to work if you pull the coil wire and test for spark, but not enough to jump the gap int eh cap and the plugs.
Re: what a puzzle
[Re: moparpro]
#2093106
06/16/16 06:21 PM
06/16/16 06:21 PM
Supercuda
About to go away
About to go away
up yours
not sure how you got test the coil out of what I wrote. Is the rotor button in the cap? Did you ohm out the coil wire?
Re: what a puzzle
[Re: moparpro]
#2094809
06/20/16 03:30 AM
06/20/16 03:30 AM
RapidRobert
Success! Curious, how far off was the dampener & what did you set the initial to?
