Re: Edelbrock Performer heads and RTV on intake bolts?
[Re: p d'ro]
#2089636
06/10/16 02:00 PM
06/10/16 02:00 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
As long as your using a PCV valve with a breather cap on the other side of the motor there shouldn't be any positive crankcase pressure to try and push oil up the threads of the intake bolts Torque the intake down to 30 to 35 lbs and make sure the bolts you use are long enough,(minumum of 1/2 inch of thread or more in the heads ) especially on aluminum heads Any time I'm using steel bolts in aluminum I use antiseize to insure no galling
[Re: Cab_Burge]
#2089639
06/10/16 02:10 PM
06/10/16 02:10 PM
Posts: 1,584 MD
p d'ro
MD
As long as your using a PCV valve with a breather cap on the other side of the motor there shouldn't be any positive crankcase pressure to try and push oil up the threads of the intake bolts Torque the intake down to 30 to 35 lbs and make sure the bolts you use are long enough,(minumum of 1/2 inch of thread or more in the heads ) especially on aluminum heads Any time I'm using steel bolts in aluminum I use antiseize to insure no galling I have it torqued now to 35 and put antiseize on the ARP bolts. They were long enough. If there is an issue I will see oil on the valley pan, correct? Thanks for the tips!
[Re: p d'ro]
#2096841
06/23/16 04:34 PM
06/23/16 04:34 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
If water is entering exhaust from engine, would it have to be from head? 440, Eddy head and Eddy CH4B manifold. Manifold should be dry.. Intake is dry and bolt holes on exhaust side as well so there is only a few places it can come from , thru a port wall, cracked cylinder, cracked head, or head gasket.
[Re: p d'ro]
#2096938
06/23/16 07:50 PM
06/23/16 07:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
For future reference, there are two pipe plugs, one on each side of the block, that you can remove to drain coolant out of the block and heads before you pull the heads. This will take most of the coolant out and minimize any coolant draining into the block/cylinders.
