Edelbrock Performer heads and RTV on intake bolts? #2089548
06/10/16 10:56 AM
06/10/16 10:56 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Hi,are the intake bolts dry like the exhaust bolts or do they need RTV? Thanks, Pete
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2089559
06/10/16 11:19 AM
06/10/16 11:19 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
I don't use rtv on mine have not had a problem. what I noticed more was the length of the bolts being an issue (big block). to short and they don't go into the head enough, to long and they bottom out. I install mine with the valve covers off so that I can see the end of the bolt, see if its to short or to long. hope this helps.
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: lokalik] #2089576
06/10/16 11:47 AM
06/10/16 11:47 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use arp intake hardware. I used anti-seize on the intake bolts. After quite a few miles it dribbles a little onto the valley tray from the passenger front bolt but not a lot.
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2089589
06/10/16 12:14 PM
06/10/16 12:14 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I used arp as well with anti seize and am now buttoning everything up. Instructions just say bolt down. I want to fix now if I need to. I actually just read on a Mopar 499 Street Hero part 3 article on web that intake bolts are open to oil on top of cylinder head so he used PFTE thread sealer...
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2089612
06/10/16 01:11 PM
06/10/16 01:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
arp thread sealer works very well.
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2089635
06/10/16 01:58 PM
06/10/16 01:58 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Ok, wasn't sure it was needed. Mine has been bolted up for two days. Am I safe to pull one bolt at a time, add sealer, and retorque?
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2089636
06/10/16 02:00 PM
06/10/16 02:00 PM
As long as your using a PCV valve with a breather cap on the other side of the motor there shouldn't be any positive crankcase pressure to try and push oil up the threads of the intake bolts work Torque the intake down to 30 to 35 lbs and make sure the bolts you use are long enough,(minumum of 1/2 inch of thread or more in the heads thumbs scope) especially on aluminum heads thumbs
Any time I'm using steel bolts in aluminum I use antiseize to insure no galling thumbs
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: Cab_Burge] #2089639
06/10/16 02:10 PM
06/10/16 02:10 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I have it torqued now to 35 and put antiseize on the ARP bolts. They were long enough. If there is an issue I will see oil on the valley pan, correct?
Thanks for the tips!
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2089676
06/10/16 03:22 PM
06/10/16 03:22 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you didn't put some thread sealer on those intake bolts, don't be surprised if you eventually find a small puddle of oil sitting on your valley pan.
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2089693
06/10/16 04:01 PM
06/10/16 04:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Teflon tread sealer, no oil puddles.
Doug
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: dvw] #2089752
06/10/16 06:26 PM
06/10/16 06:26 PM
I've assemble and ran a bunch of BB with stock iron heads and now with different brand and sizes of alumimun heads originally with oil only on the bolts with no issues.I started using anti seieze several years back on the intake bolts with aluminum heads and no issuues with that either shruggy
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2096802
06/23/16 03:04 PM
06/23/16 03:04 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Update:
Got the car back together and started. Ran great... For about 15 seconds.
Poured oil out the valve covers. Oops, forgot to tighten them...
Poured gas on hot manifold. OMG! Fuel line must have cross threaded in carb? Will address it.
Started to blow white smoke out of passenger tail with significant wetness.Instantly thought head issue but I am hoping it is just all of the coolant that poured out of my head and block during my work that may have dumped right in to the collector. I am crossing my fingers.
Oil pressure good. Temperature was good. Oil is clean (no milky look). Idled great but sputtered thru carb whenI blipped the throttle. I am hoping that was from the fuel leak. I will get back at it in a few days and give another update.
If water is entering exhaust from engine, would it have to be from head? 440, Eddy head and Eddy CH4B manifold. Manifold should be dry..
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2096841
06/23/16 04:34 PM
06/23/16 04:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Intake is dry and bolt holes on exhaust side as well so there is only a few places it can come from , thru a port wall, cracked cylinder, cracked head, or head gasket.
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2096934
06/23/16 07:43 PM
06/23/16 07:43 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Thanks John. As I suspected...
So fixed fuel leak and realized I did not tighten up collectors so had major exhaust leak (ok, it was late and I am a rookie). Hopefully that was causing sputtering as it idles great. After I tighten those up I will get it outside and try to see if the white smoke stops..
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2096938
06/23/16 07:50 PM
06/23/16 07:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
For future reference, there are two pipe plugs, one on each side of the block, that you can remove to drain coolant out of the block and heads before you pull the heads. This will take most of the coolant out and minimize any coolant draining into the block/cylinders.
Don't be the exception.
Re: Edelbrock Performer heads and RTV on intake bolts? [Re: p d'ro] #2097209
06/24/16 09:11 AM
06/24/16 09:11 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Thanks for the tip. That would have prevented the mes I made.
So if the head is leakingninto the cylineer would the white smoke appeaf immediately pon start up or could it take time to appear. My car is not blowing it until it warms up.
