Re: Difference between passenger and driver side leaf springs
[Re: 2ndopp]
#2092381
06/15/16 12:25 PM
06/15/16 12:25 PM
Posts: 3,386 KY USA
mopargem
KY USA
If my memory serves me, you need to check the locator pin size on 73 up. I believe it is a different size than earlier cars. You may have to weld a washer with smaller hole onto the pearch pad unless you can find aftermarket springs 73 up which I don't think is avail?? I could be wrong on all of this but it comes to mind. Remember your 73 up B body is iso suspension
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#2092571
06/15/16 05:36 PM
06/15/16 05:36 PM
Posts: 10,951 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I have the Mexico SS springs on my 70 Bee. Once I got everything bolted together, front bolts in the upper hanger holes and weight on the wheels, they set just right, but I will say that pinion angle was all screwed up and I had to put spring perch wedges in to get the rear yoke back in line. I've seen INSANE variations in SS springs. Dave Pelletier's 70 bee gets the award for the craziest arch I've ever seen. No kidding. He had about 6 inches between the wheel well and the top of the tires!
I’m listening.
[Re: mopargem]
#2092939
06/16/16 12:10 PM
06/16/16 12:10 PM
Posts: 78 AZ
2ndopp
AZ
If my memory serves me, you need to check the locator pin size on 73 up. I believe it is a different size than earlier cars. You may have to weld a washer with smaller hole onto the pearch pad unless you can find aftermarket springs 73 up which I don't think is avail?? I could be wrong on all of this but it comes to mind. Remember your 73 up B body is iso suspension Will do, especially since Espo quoted me $390 for new leafs shipped. Now I'm tempted to just use what I have and save up for a 4-link.
