Re: Difference between passenger and driver side leaf springs [Re: 2ndopp] #2092352
06/15/16 11:41 AM
06/15/16 11:41 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
if i were you, i would put the car up on jackstands at the frame in the rear and use a jack to drop the axle down and see if i could compare the arch of the original springs and the XHD springs.
the XHD springs are supposed to be just like the factory 440/hemi springs, and there is an all original Coronet RT i've seen a few times and that car sits pretty much perfectly level at a moderate ride height.
Re: Difference between passenger and driver side leaf springs [Re: 2ndopp] #2092381
06/15/16 12:25 PM
06/15/16 12:25 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
If my memory serves me, you need to check the locator pin size on 73 up. I believe it is a different size than earlier cars. You may have to weld a washer with smaller hole onto the pearch pad unless you can find aftermarket springs 73 up which I don't think is avail?? I could be wrong on all of this but it comes to mind. Remember your 73 up B body is iso suspension
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Difference between passenger and driver side leaf springs [Re: mopargem] #2092571
06/15/16 05:36 PM
06/15/16 05:36 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I have the Mexico SS springs on my 70 Bee. Once I got everything bolted together, front bolts in the upper hanger holes and weight on the wheels, they set just right, but I will say that pinion angle was all screwed up and I had to put spring perch wedges in to get the rear yoke back in line. I've seen INSANE variations in SS springs. Dave Pelletier's 70 bee gets the award for the craziest arch I've ever seen. No kidding. He had about 6 inches between the wheel well and the top of the tires!
I’m listening.
Re: Difference between passenger and driver side leaf springs [Re: mopargem] #2092939
06/16/16 12:10 PM
06/16/16 12:10 PM
AZ
2
2ndopp Offline OP
2ndopp  Offline OP
AZ
Will do, especially since Espo quoted me $390 for new leafs shipped. Now I'm tempted to just use what I have and save up for a 4-link.
