SB iron head porting info needed...
#2083831
06/01/16 02:01 AM
06/01/16 02:01 AM
Posts: 1,770 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Guys! I'm making a few tiny adjustments to my factory 596 heads (previously DIY ported using the MP templates). This is what the heads looked-like when I had finished them up: My current adjustments really just thin out the valve guide boss further (slim it down). I also would like to remove the roof bump as in the following photo (keep in mind, the head is upside-down, so deck is pointing up): My original attemp to do this resulted in breaking through, luckily this was on the sunk-in head-bolt, so epoxy took care of the issue, here is what that looked like: ...and the fix looks like this: Alright...so as best as I can there I should not have this type of an issue with any other ports...the head-bolts there all are raised. Also, as best as i can tell there is no WATER passage in this area...is that correct? Or is this a bad idea?
Re: SB iron head porting info needed...
[Re: Diplomat360]
#2083854
06/01/16 02:56 AM
06/01/16 02:56 AM
Posts: 4,457 Washington
madscientist
Washington
You should have made a spacer and let it fill the hole. Then you can grind the port out to where you want it. Then you use the longer head bolt.
Pretty nice work.
Pay berry close attention to the valve job, especially the top cut.wider is better.
[Re: Diplomat360]
#2083855
06/01/16 02:57 AM
06/01/16 02:57 AM
madscientist
Washington
And you can grind out into the valve cover bolt hole and get rid of the lump. I've never had one leak.
[Re: Diplomat360]
#2084003
06/01/16 12:34 PM
06/01/16 12:34 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
As with many OE heads, when you start trying to get a lot more air through the ports, the short turn starts to become an issue. SB mopar heads are no different.
My experience has been that trying to completely remove the humps in the roof by the head bolts is worth almost nothing unless it's a truly MAX effort deal.
The short turn needs to be layed back as much as you dare...... And yes, there is water right there, so use caution. This is the one key area of the intake port that is noticeably different in an X head than the other SB mopar heads. The short turn is already layed back quite a bit compared to any other stock SB mopar head, if they both have a 2.02 valve. I find it fairly difficult to get these heads to not start to back up(turbulence) at much over .500 lift, if you've got the rest of the port opened up to allow a noticeable increase in airflow(say around 240cfm and up). What I often do is use 2.055/1.625 SBC valves, which provides a nice flow increase in the area under curve, although it doesn't help with the ports backing up at high lifts. If you're starting from scratch, the 1.625 exhaust valve is an easy way to perk up the flow.
[Re: madscientist]
#2084308
06/01/16 09:48 PM
06/01/16 09:48 PM
Diplomat360
Windsor, ON, Canada
And you can grind out into the valve cover bolt hole and get rid of the lump. I've never had one leak. Did you end up using studs there or just a straight forward valve cover bolt? Seems like this would be an easy way to remove a sizeable bump in an otherwise tight port area...but I've ready various on-line stories of ensuing constant oil leaks, etc, etc...
[Re: Porter67]
#2084311
06/01/16 09:52 PM
06/01/16 09:52 PM
Diplomat360
Windsor, ON, Canada
If your thin on the tube side this is cheap easy backup, and most holes need very little prep.
I epoxy the heck out of them and if they are tight, leave a 1/2 inch and use a wood block and a bfh, then trim them. Hmm...well, a few years back when I was really putting some serious time into porting these I wish I had this info (re: tubes) as I would have most likely tried to do this on my own. At this point in time I am really just looking for small (read: easy...LOL) improvements as I indend to start by W2 stroker build this winter and am really only looking for another 1-2 yrs use out of these heads...certainly not a max-effort type either. Good info to have, part number/brand name saved!!!
[Re: Diplomat360]
#2084316
06/01/16 09:58 PM
06/01/16 09:58 PM
madscientist
Washington
And you can grind out into the valve cover bolt hole and get rid of the lump. I've never had one leak. Did you end up using studs there or just a straight forward valve cover bolt? Seems like this would be an easy way to remove a sizeable bump in an otherwise tight port area...but I've ready various on-line stories of ensuing constant oil leaks, etc, etc... I've used both a stud and a bolt. Never had a leak. The heads I'm using now have broke through all the upper valve cover bolts and I'm using a bolt with no leaks. I have W2's with everything to swap them out. Just needs to do them up.
[Re: fast68plymouth]
#2084317
06/01/16 10:00 PM
06/01/16 10:00 PM
Diplomat360
Windsor, ON, Canada
...My experience has been that trying to completely remove the humps in the roof by the head bolts is worth almost nothing unless it's a truly MAX effort deal...
Yeah...certainly this is NOT one of these MAX effort situations...only looking for easy improvements. As-is, here are the port flow numbers off of a SF-600 bench: LIFT I E 0.100 67 57 0.150 99 79 0.200 130 104 0.250 162 125 0.300 189 140 0.350 215 152 0.400 235 160 0.450 253 167 0.500 262 172 0.550 261 175 0.600 248 177 ...I find it fairly difficult to get these heads to not start to back up(turbulence) at much over .500 lift, if you've got the rest of the port opened up to allow a noticeable increase in airflow(say around 240cfm and up).
So I think I saw precisely that behaviour with my heads...the flow numbers started dropping off right at the .550" mark. ...What I often do is use 2.055/1.625 SBC valves, which provides a nice flow increase in the area under curve, although it doesn't help with the ports backing up at high lifts... If I was re-doing this, yes, I would probably go with a 2.05" valve, but for now, it stays as-is. No more money to sink into these casting...I am saving up for the W2 Econo heads next...LOL.
[Re: Diplomat360]
#2084321
06/01/16 10:05 PM
06/01/16 10:05 PM
madscientist
Washington
So I think I saw precisely that behaviour with my heads...the flow numbers started dropping off right at the .550" mark. ...What I often do is use 2.055/1.625 SBC valves, which provides a nice flow increase in the area under curve, although it doesn't help with the ports backing up at high lifts... If I was re-doing this, yes, I would probably go with a 2.05" valve, but for now, it stays as-is. No more money to sink into these casting...I am saving up for the W2 Econo heads next...LOL. When you go to a bigger valve, it makes the port break over and go turbulent sooner. You can't get enough port area above the short turn and you can't slow the air over the short turn no matter what you do. You are at the point of making sure the chamber and the valve job are as good as you can get. Pay very close attention to the top cut. Even if you lose flow, if the chamber/top cut are good you will make more HP. Make sure you lift average and get as much lift as you can. Even past the point of flow back up.
[Re: Diplomat360]
#2084430
06/02/16 01:36 AM
06/02/16 01:36 AM
fast68plymouth
So. Burlington, Vt.
LIFT I E
Those are pretty good numbers for that level of work. Pretty close to what my old 587's flowed that I ran on my 340. That motor made 478hp with flow numbers like that.
[Re: Diplomat360]
#2084679
06/02/16 04:25 PM
06/02/16 04:25 PM
Posts: 883 Affton MO
qwkmopardan
Affton MO
Guys! I'm making a few tiny adjustments to my factory 596 heads (previously DIY ported using the MP templates). This is what the heads looked-like when I had finished them up: My current adjustments really just thin out the valve guide boss further (slim it down). I also would like to remove the roof bump as in the following photo (keep in mind, the head is upside-down, so deck is pointing up): My original attemp to do this resulted in breaking through, luckily this was on the sunk-in head-bolt, so epoxy took care of the issue, here is what that looked like: ...and the fix looks like this: Alright...so as best as I can there I should not have this type of an issue with any other ports...the head-bolts there all are raised. Also, as best as i can tell there is no WATER passage in this area...is that correct? Or is this a bad idea? You can go farther. M/P made a kit with a pair of plugs and 2 of the longer head bolts. Counterbore varys from head to head so I make my own plugs to fit each head perfectly. Get a head bolt kit for W2 heads and it has 4 of the longer bolts. If you are careful, you can get 1.02" through the pushrod pinch without tubes.
[Re: qwkmopardan]
#2084892
06/02/16 10:52 PM
06/02/16 10:52 PM
Diplomat360
Windsor, ON, Canada
...You can go farther. M/P made a kit with a pair of plugs and 2 of the longer head bolts. Counterbore varys from head to head so I make my own plugs to fit each head perfectly. I have read stuff about the MP plugs before, but never knew what they were used for...now I do...thanks! So how do you make your own? What do you use? Is this something you machine, or have someone machine for you?
[Re: Diplomat360]
#2084971
06/03/16 12:38 AM
06/03/16 12:38 AM
madscientist
Washington
I machined mine out of aluminum on the lathe. I epoxied them in and the ground them flush in the port.
[Re: Diplomat360]
#2086080
06/04/16 10:34 PM
06/04/16 10:34 PM
Posts: 617 PA
bwhackd34
PA
About the valve cover bolt boss...don't worry about it! Grind it out! Years ago...in the early 90's I worked for a guy that did a lot of rounds rounders. They used 9:1 358, no porting...1" in from valve seat and 1" in from intake face. They had to use stock block, a factory head...the Chevys could use a bow tie...any cast manifold and a 650 Holley on alky. When I started they were dynoing right around 435 hp. I started doing the heads and when I left we were making 585-595hp!!! We were ALWAYS tech'd...they all thought we were cheating but the heads always passed! We had track champions at almost all the tracks and always had guys up front! Our stuff was fast!!!! Everybody wanted a CMS Racing Engines motor back then! Back then it was taboo to touch the SSR and the closed chambers were thought to be the best because they could make compression. When the second gen bow tie heads came out they had a bathtub type chamber versus the first gens which were more of a semi-open design. I remember the first time I started laying back the SS and the chamber and everyone told me that you can't do that. I even saw a lot of Slawko stuff from the time and they never did either. I was told "look at them...they are the pros"..."you ruined those heads"...until the flow numbers went from the high 120's @ 10"....an SF-110 back then....to 155-158@ 10" and we made TONS of power....these days every one knows those areas can give the biggest gains but also the biggest heartaches....ask me how I know.... My point is that almost everyone of those heads had the boss ground out and I never thought twice about it!
