Aftermarket A/C #2087147
06/06/16 04:47 PM
06/06/16 04:47 PM
missouri, USA
moparmojo Offline OP
missouri, USA
Guys I'm in the planning stages of getting the body on my 1970 Challenger Convertible redone and questioning what I should do about A/C. Wondering what everyone's opinion is on:
* Install an A/C firewall and use factory air parts
* Install a non-A/C firewall and go with an aftermarket A/C set up or some combination of the two?
If anyone has any pics of their aftermarket A/C set up, please share. Your opinions welcomed as well. Thanks
Re: Aftermarket A/C [Re: moparmojo] #2087217
06/06/16 06:34 PM
06/06/16 06:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Vintage air all the way
Re: Aftermarket A/C [Re: moparmojo] #2087297
06/06/16 08:28 PM
06/06/16 08:28 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
I would use Vintage Air using the stock vents were possible.
That is if you want the AC Dash pad
Or they have a complete kit for Challengers
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Aftermarket A/C [Re: moparts] #2087366
06/06/16 10:27 PM
06/06/16 10:27 PM
IN
ahy Offline
ahy  Offline
IN
Starting with a non AC car, I would go all aftermarket. Finding and restoring a complete OE AC setup + changing the firewall would be time consuming and expensive. I understand the aftermarket units work well and are a lot lighter. Only downside is you give up fresh air. I doubt that would be a problem with a convertible.
Re: Aftermarket A/C [Re: gtx6970] #2087404
06/06/16 11:00 PM
06/06/16 11:00 PM
missouri, USA
missouri, USA
Gtx beautiful engine bay. Did your car have an AC firewall initially and/or what is that black circle where the AC lines enter through the firewall? what I am trying to do is plan ahead and determine the best plan of action where the firewall is concerned to make it appear the cleanest it can be.
Re: Aftermarket A/C [Re: moparmojo] #2087430
06/06/16 11:28 PM
06/06/16 11:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Original non air car. The black circle is a plate that covers where the original blower motor sticks out.
After using this,,,there's no way I would go to the trouble of changing firewalls .
As an FYI, If I had it to do over again, I would find an original AC dash pad. It gets really tight quarters under the dash routing all the AC hoses to exit under a non air pad
Re: Aftermarket A/C [Re: moparmojo] #2087510
06/07/16 01:32 AM
06/07/16 01:32 AM
USA
brando Offline
brando  Offline
USA
I installed Vintage Air in may 1973 Charger. Be prepared to make some minor modifications. Talk to as may people as you can that have installed A/C in a Challenger and ask them to take pictures
A member with a 73 Charger took pictures of his A/C installation for me that helped me immensely.
Re: Aftermarket A/C [Re: gtx6970] #2087791
06/07/16 03:58 PM
06/07/16 03:58 PM
missouri, USA
missouri, USA
My Challenger already has an Air dash. The firewall needs to be replaced regardless of which route I go.But wonder if it is better to use an air firewall with aftermarket AC and a cover plate or use a non-air firewall with aftermarket AC for a cleaner look?
Re: Aftermarket A/C [Re: moparmojo] #2087886
06/07/16 07:09 PM
06/07/16 07:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I put the Vintage Air system in my '69 Coronet, and I like it except for the way the route the hoses under the fender. If I did this again I would use a bulkhead connector and run the hoses in the engine compartment.
Re: Aftermarket A/C [Re: brando] #2088071
06/08/16 12:00 AM
06/08/16 12:00 AM
TC, Minnesota
Gabmando Offline
Gabmando  Offline
TC, Minnesota
brando I too would like to install aftermarket AC in my 73 Charger Rallye. I really would appreciate it if you would please share those pictures with me. thanx.
