XR-2 Meeting Original Goals/Purpose????? #208648
01/30/09 01:58 PM
01/30/09 01:58 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
I as many others have been waiting anxiously for seems like a year or more now for the XR-2 to show it's face. It was my understanding that one of the primary purposes of the XR-2 program was to provide a platform for the P7 heads that could use many existing LA engine parts.
From what I have been able to determine there's not a heck of a lot of LA parts that will be usable.
- Certainly the top end will be totally different with the P7 hardware.
- Camshaft will not be usable. Must use special 60mm cam core. Did someone have a stockpile of parts they needed to move??
- Lifters from an LA engine will not be usable, totally different lifter layout.
- Pistons will have to be custom for the P7 chambers.
- There may be some applicability for existing crank and rods??
- Timeing chain/gear drive??
- Timing chain cover will be usable!!
- Damper will be usable??
- Pan will be usable??
- Distributor will be usable??
- Hopefully the bellhousing bolt pattern will be LA??
If I'm wrong I sure wish someone would set me straight, I'm getting a very uneasy feeling about exactly what will be required to put together a strong XR-2/P7 combination!!!
Re: XR-2 Meeting Original Goals/Purpose????? [Re: Blucuda413] #208649
01/30/09 06:39 PM
01/30/09 06:39 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
I will give ya a bump here and by no means am I a XR expert
The nice thing about the XR block is.........
its a wet sump
takes stock pan
stock timing cover
has factory bell housing bolt pattern
as far as the lifters and cam go you would need to buy $$$$ pricey race stuff anyway to take advantage of the P7 heads anyway. A stock cam would flex and could not be ground to take advantage of the heads anyway.
the used R5 lifters are dirt cheap if you want good used stuff.
its not perfect but it will let you build a big inch P7 headed motor with out breaking the bank
Re: XR-2 Meeting Original Goals/Purpose????? [Re: 340RICK] #208650
01/30/09 09:19 PM
01/30/09 09:19 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Some people have stockpiles of parts that will fit these engines. It's not a greed thing as you would not want lifter spacing and a camshaft from an LA as it would not work due to valve locations.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: Leon441] #208651
02/02/09 10:20 AM
02/02/09 10:20 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Well everything up to the cam stock LA stuff. From The cam up will utilize R5/P7 stuff. And the cam will actually have to be special from what I'm told. I was just informed that the R5 cam wont work with this block cause the front of the cam is not machined for LA style timing chain and he wasn't sure if the front could be remachined or not. But he said comp cams is making the cam for this setup. I forgot to ask what gear they wiil be running on the cam, if they use the LA gear it will be very easy to make wet sump, if they use the R5 gear it will be a little more difficult. Lifters are super cheap don't be scared by them. Go with the .905 nascar lifters and you'll be out about $250.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: XR-2 Meeting Original Goals/Purpose????? [Re: DemonDust] #208652
02/02/09 10:49 AM
02/02/09 10:49 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I, for one, find it extremely odd that the people associated with this project
are always absent from these posts. That sends me a bad message.
I know the first run of XR-? blocks was to be machined January of 2008, with
the release to follow soon after.
I'm not bashing anybody or trying to stir the crap but, I'd think those involved
would address these XR posts and at least keep interested parties up to date
on their progress, or lack thereof.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: S/ST 3040] #208653
02/02/09 11:13 AM
02/02/09 11:13 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Those involved are too busy to sit and type.
You need to call them personally.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: theclutcher] #208654
02/02/09 11:35 AM
02/02/09 11:35 AM
S/ST 3040 Offline
S/ST 3040  Offline
I know Kent isn't a member here and wasn't referring to him
but, you're right......he's currently in a meeting.
Like I said, I'm not trying to stir anything up but, I think
people who are interested deserve some answers from the
people who advertised it's production. They must have been
a lot less busy then.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: S/ST 3040] #208655
02/02/09 05:21 PM
02/02/09 05:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
I just got off the phone with Kent Ritter.......
He told me the project is still going forward but, has taken longer
due to some manufacturing changes. There are both XR-1 and XR-2
blocks out there but, all current blocks and ones in upcoming run are
already spoken for. He projects to be caught up and in full production
by early April.
That's all I asked so, that's all I know. The good news is he says they will be available.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: S/ST 3040] #208656
02/02/09 06:34 PM
02/02/09 06:34 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Are you happy now?
I did'nt realize that anyone involved in that block project had to answer the same questions that get asked over & over everytime a post like this comes up. Yes some of us ARE busy.
When the blocks are more readily available you'll hear about it.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: RyanJ] #208657
02/02/09 08:40 PM
02/02/09 08:40 PM
S/ST 3040 Offline
S/ST 3040  Offline
I'm rarely happy and smartass remarks don't seem to help.
Some of these guys seem to be interested in the XR stuff
and have questions about it. You are one of the people who
were advertising this stuff. If I had questions about something,
somebody was selling, I'd want them answered before I started
laying out the cash.
It looks like you have time to respond now. It's not like this
just got put up here today. I was just speaking my mind. You
never seem to have a problem telling people what you think.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: S/ST 3040] #208658
02/03/09 07:20 AM
02/03/09 07:20 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
I have to agree with s/st 3040, these do seem to be taking a while. I dont know how you can advertise and take deposits on something that is not readily available.
Seems like maybe the xr blocks to suit the w series or 59 deg heads should have been cast first to iron out the bugs and get a few runs on the board with the mopar public. There is probably more people waiting for those style than the one to suit the p7?
Re: XR-2 Meeting Original Goals/Purpose????? [Re: S/ST 3040] #208659
02/03/09 10:04 AM
02/03/09 10:04 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I only make smartass remarks when some are directed at me first there Vic.. I was drug into this post by YOUR remarks seeing as how only Rick & I were the only two to ever do much "advertising" about those blocks I have to infer that you were referring to us. Like I said, when they are more readily available we will be more than happy to let people know. Yes they are taking alot longer to be produced than ANYONE wants, me, Rick, Kent, the general public etc. It's not an easy deal, people need to learn patience.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: RyanJ] #208660
02/03/09 10:25 AM
02/03/09 10:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Ryan.....Get off the computer and answer you're phone .
Re: XR-2 Meeting Original Goals/Purpose????? [Re: RyanJ] #208661
02/03/09 10:25 AM
02/03/09 10:25 AM
S/ST 3040 Offline
S/ST 3040  Offline
Now that we have that out of the way, can you just answer Max's
questions. You've already dedicated enough time here to answer
them. If I knew the answers, I'd help but, I don't. This is no more
repetitive than the 8 3/4 posts.
Sorry for butting in Max.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: vc360] #208662
02/03/09 11:38 AM
02/03/09 11:38 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Its the same casting as far as I know.
Also was told they werent taking deposits and have not due to this very concern.
Dont want to have to listen to the crying in case difficulties arise in production.
Anybody that has been seriously interested , could have had one.
Like anything else, step up or step aside.
Doubtful the 59 degree would be more desireable with current cost of p7 parts imo.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: S/ST 3040] #208663
02/03/09 11:55 AM
02/03/09 11:55 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Anyone who is seriously interested in building one should contact Rick, he is the one in charge of the XR2 P7 development. I specialize in wedge motors.
I know most of the answers on the XR2 questions, but not everyone is going to be thrilled when they hear them. It did end up swaying more toward a modified R5 deal than was I think originally intended. The 3 biggest things it will allow is the use of an off shelf 340 main crankshaft (try that in your R5 or $6000 EEI block) Which opens up the stroke avenues greatly without having to do a custom billet. No stupid R5 trans adapters..... & the cost is about 1/2 of an EEI block. Those are basically it's 3 biggest benefits.... If those 3 things don't help, just go do an R5 or an EEI block.
I'll start working on them when blocks are more available. I'd rather have people ask Rick specific questions because he has actually worked on them.... In reality Rick is the ONLY one qualified to answer specific tech questions about the XR2/P7. Kent can answer questions as well, but Rick actually has more hands on experience with them than Kent so.... anything else you hear about them is pretty much hearsay or second hand info, which is what I'm giving here & I don't like giving second hand info. Only specific things I know about them I have gotten from talking with Rick about them, & some of the production problems from Kent. So that's why these 2-3+ posts a week about the XR stuff are hard to deal with because only a few people have the answers & they are too busy to be answering Q's everytime some pop up. Just gonna have to wait until some are finally running to get good grasp on what can & can't be done.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: theclutcher] #208664
02/03/09 12:01 PM
02/03/09 12:01 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Actually the one XR1 I have on order is a 59* Tall deck 340 main. & if they were more readily available I would have bought a couple more recently, just had to buy some R3's through the dealer instead. Most people still want wedge motors that I talk to... Only the real hardcore Drag/Circle guys want to try the P7's.
There's a handfull of XR1's out around the Country right now, I think almost all of them are being done as circle track engines.
From everything I have seen & been told, the castings are awesome.... it's the machine shop that is causing the issues with the blocks.
Re: XR-2 Meeting Original Goals/Purpose????? [Re: RyanJ] #208665
02/03/09 12:17 PM
02/03/09 12:17 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Thats one big load of crap...twice I tried over the past year with CC in hand...first time I was told I would be put on the list, last time I just missed the one they just sold from there web site by a day.
Just to sum it up without dragging more BS into it....if the big dogs cant get them...how can us little guys get them.
I wont post the reply I got from one of the "Big Dogs" But no one seems happy or getting blocks.
Why are the same people pushing alot of R5 products if the XR block is just around the corner?
In my reaserch on the R5/P7 this whole XR idea has been around on the net since 2003 where posted it wont be long and this was in 2003.
At this point if the XR makes it or not, who cares, new R5 blocks can be had for a little as $1500.
Im told my R5 to small block adapter plate ships tomorrow from the same makers of the XR blocks.....I would love to have an xr block, but untill I can call and order, pay and have it shipped, why try?
My R5/P7 will be on the pump within a month....it might not be my first choice but its a hands on part here and now.
I hope it all comes together but until there is a proven tested soild product in stock ready to ship, naaa, now with all the current changes in some of it, doesnt it seem its still in the RnD process since 2003 or???
Re: XR-2 Meeting Original Goals/Purpose????? [Re: quick77rt ] #208666
02/03/09 12:37 PM
02/03/09 12:37 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I'm gonna have to go ahead and agree with Mark on the comment "Anybody that has been seriously interested , could have had one.
Like anything else, step up or step aside."
That is not a true statement. There are lots of people "seriously interested" that don't have blocks yet. So be careful before you talk about what you don't know.
SDG Motorsports
Re: XR-2 Meeting Original Goals/Purpose????? [Re: DemonDust] #208667
02/03/09 02:02 PM
02/03/09 02:02 PM
France Europe
Laurent Offline
Laurent  Offline
France Europe
Hello Jesse
If Xr1/2 blocks aren't yet available for everyone.... You could probably sent me the parts you're supposed to supply me since over one year... It seemed you fixed stainless W9 flanges story but you forgot me(ARP w9 stand bolts....)...
Let me know...
Laurent.
