Old school 500 cubic inch on the cheap? #208582
01/30/09 12:29 PM
01/30/09 12:29 PM
Holland MI Ottawa
2
2boltmain Offline OP
Holland MI Ottawa
Before affordable stroker kits mopar guys could..If I recall correctly buy a stroker crank or have a 440 crank welded/regound, use oem 440 rods and smogger off the shelf cast pistons in an RB block. This made 500 cubes. Heavy rotating assembly (compared to current stuff) and not recommended beyond 5500 RPM but a big torquer none the less. My question: Could a cheap stroker (reliable street only engine) be made now with a new stroker crank (under $400) and then oem rods and off the shelf cheap cast low compression 440 pistons? Would the pan rail need clearencing? Bouchillion Performance in the early 90s advertised a stroker kit this way. They recommended the mopar 484 cam and no bigger. Specifically said the 509 made no more power.
Keep old mopars alive.
Re: Old school 500 cubic inch on the cheap? [Re: 2boltmain] #208583
01/30/09 12:40 PM
01/30/09 12:40 PM
I've been on this myself. definitely want cast pistons & I had checked out some 403 olds pistons. 4.351" bore/1.585 CH. they're on eGay for cheap. I'd prefer a B block & I'd have to fab an external oiling system. I haven't found the right combo yet
Re: Old school 500 cubic inch on the cheap? [Re: 2boltmain] #208584
01/30/09 02:05 PM
01/30/09 02:05 PM
AndyF Offline
AndyF  Offline
I don't think you can get parts for less money than a 440Source stroker kit. Maybe if you find a cast piston that works but I'm not so sure there are any. KB might have a cast piston for stroker motors so you could start there.
Re: Old school 500 cubic inch on the cheap? [Re: AndyF] #208585
01/30/09 02:17 PM
01/30/09 02:17 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Actually Indy is selling a kit right now for LESS and if you look on ebay they are available
Re: Old school 500 cubic inch on the cheap? [Re: JohnRR] #208586
01/30/09 03:35 PM
01/30/09 03:35 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
The original old school 500 inch was to
get an old caddy 500" engine
logan426
Re: Old school 500 cubic inch on the cheap? [Re: MLR426] #208587
01/30/09 03:37 PM
01/30/09 03:37 PM
U.S.S.A.
U.S.S.A.
logan426
Re: Old school 500 cubic inch on the cheap? [Re: 2boltmain] #208588
01/30/09 04:46 PM
01/30/09 04:46 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Smogger 440 pistons have a higher compression height than your typical stroker piston for a 4.15" stroke crank. They'd be around .020 or so above deck. No problem there, just use a little bit thicker head gasket and you are good to go. Problem is they've got no valve reliefs so I don't think you could really run much of a cam. Yeah you can buy a jig to cut valve reliefs but by the time you've gone through all that BS you might as well have just dropped the $440 for a set of forged KB pistons for that stroker combo.
BTW, where do you get a stroker crank for under 400 bucks?
Re: Old school 500 cubic inch on the cheap? [Re: DaytonaTurbo] #208589
01/30/09 05:05 PM
01/30/09 05:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
With a final balanced kit with H beam rods $1897!! why would you even think of trying to coble something together????? It's the new millennium Man!!!!
That said you can use this piston
400 - Comp / Dist - 1.817 (Set of 8)
We stock STD. / .030 over, all other sizes need to be special ordered
$303.95
SEA406AP
4.15 crank and stock 6.76 rods and be .070 down the hole and with a 86 cc head be at 9.8 to 1 compression about!!
Re: Old school 500 cubic inch on the cheap? [Re: 2boltmain] #208590
01/30/09 07:00 PM
01/30/09 07:00 PM
We used to use a welded stroker crank, stock rods and 400 pistons.
All you would save now is maybe $100 by using cast 400 pistons. You'll be much better off using a new crank (for less than we used to pay to have them welded) and specific pistons with valve reliefs and the correct deck height. Nothing to be saved here.
Sheldon
Re: Old school 500 cubic inch on the cheap? #208591
01/30/09 08:28 PM
01/30/09 08:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its unreal the torture some people put themselves through !!!
Re: Old school 500 cubic inch on the cheap? [Re: 2boltmain] #208592
01/30/09 10:53 PM
01/30/09 10:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I priced out a few stroker options before I got my 440. Really it is hard to beat the pre-fab kits sold. It saves time and money. Oh and don't use either 484 or 509, their are much better grinds available today...easpecially if you're going to run 500 cubes.
Re: Old school 500 cubic inch on the cheap? [Re: Mr.Yuck] #208593
01/30/09 11:07 PM
01/30/09 11:07 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Actually the "on the Cheap" was to reuse your 400 pistons (Longer CH 440's won't work) and bore your 440 block to 4.342" (.022 over) and then (IIRC) use the 4.15 crank and the 440 LY rod and you get ~491 cubes.
You might need to check my math but I think that's right...at least it's feasible.
It'll be heavy and I think the slug still winds up down in the hole but the bottom end will lighter than a stock 440 and it'll be cheap (the cost of the crank and balancing).
I mocked one up that way with spare parts but I never built it...you'll be limited on cam lift due to no eyebrows inthe slug but if you want a low buck torque motor I'll bet a MP 528 solid would clear.
But I could see a very low buck "junkyard" torque motor turning high 11's or lower pretty easy.
WIZE
In Car:
Re: Old school 500 cubic inch on the cheap? [Re: Streetwize] #208594
01/31/09 12:01 AM
01/31/09 12:01 AM
Manitoba, Canada
Manitoba, Canada
Again, even if it was doable, why would you not run the KB forged piston for the 4.15" stroke based 440's? Summit lists those pistons for $441.00. At least with those you can build a zero-deck quench engine or a domed piston build. Last time I checked, a new set of cast 400 or 440 pistons listed for $350. For the extra 90 dollars I think it's worth it to just get the proper pistons. Really, when doing a stroker build like that, the crank is the biggest expense.
Re: Old school 500 cubic inch on the cheap? [Re: DaytonaTurbo] #208595
01/31/09 01:35 AM
01/31/09 01:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
The welded stock crank 4.15/LY/Ross piston combo is still alive and well in my Mirada. I did run the heavy 400 slugs for one year with home ported 906 heads. Ran low 11's with a MP .557 cam.
Same short block with Ross pistons, Stage VI heads, UD NF69 cam has gone a best of 10.04 @ 135.
Re: Old school 500 cubic inch on the cheap? [Re: RapidRobert] #208596
01/31/09 05:23 AM
01/31/09 05:23 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
A couple of Q's here on the pistons .....
The 403 Olds ? ... did you use them bone-stock? .. no mods to the piston deck or pins ?
The KB's that were mentioned ... these are forged ? ...
Now on the top ring location vs top of piston ? .... what is the minimum spec? (no spray or boost)
Re: Old school 500 cubic inch on the cheap? [Re: dOoC] #208597
01/31/09 11:01 AM
01/31/09 11:01 AM
Nothing yet it's just on paper(& in my head ). I am a quench fanatic & I cant get it with all the combo's I dreamed up so using the olds piston my be out & they are a dished piston so I'd have to machine the outer perimeter down. the pins are .9804" another problem, then buy the cutter & notch for valve clearance but maybe not needed as I had plannd on a stock cam. Sometimes I thrive on misery & as mentioned this might be one of these occaisions but I cant see $1899 for a 440 source kit when I just want to throw together a BB for a daily driver 65 dart(hence the cast pistons) plus their kits MAY or may not need more work. I didn't catch the KB ones you mentioned but they are probably hypers & it'd be on their site to easily access. standard ring gap would be ~.004" per inch of bore dia(top ring) unless it's a KB hyper then maybe .0065" per inch but check their chart and .003" per inch of bore dia on the 2nd ring. EDIT oh you asked about location as in if you'd mill the tops? I dont know the ans on that.
Re: Old school 500 cubic inch on the cheap? [Re: RapidRobert] #208598
01/31/09 11:05 AM
01/31/09 11:05 AM
U.S.S.A.
U.S.S.A.
that would be correct , it's going to cost MORE in time and money to make that combo work , if it's even possible , you'd be better off with a cast 400 piston .
check ebarf for hawksracing , he sells stroker cranks for 495ish , use stock rods and 400 pistons . but yes KB has a shelf piston that will be eaiser to work with I'm pretty sure in both forged , but definitely hyper .
Re: Old school 500 cubic inch on the cheap? [Re: RapidRobert] #208599
01/31/09 11:12 AM
01/31/09 11:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Here's a thought...why not just build a 440? any year will work, bore it .060 That gives you what???? 453ish cubes??? Then call Summit and order a set of pistons for it. Not sure what heads you are going to use. I'd guess depending on the rest of your set-up, stall rear gear and such you could pick a cam. For street use those extra cubes will probably just blow the tires up. You can go old scholl and get a 400, use a 440 crank and chevy rods for a 451, those run good. The problem I see is there really is no "cheap" engine build. Especially when a machine shop is involved. Some body here uses this as their tag line and it is true
"cheap, fast or reliable" pick 2 because you can't have all 3".
Re: Old school 500 cubic inch on the cheap? [Re: JohnRR] #208600
01/31/09 11:23 AM
01/31/09 11:23 AM
Thank you John, I will
Re: Old school 500 cubic inch on the cheap? [Re: RapidRobert] #208601
01/31/09 11:36 AM
01/31/09 11:36 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
buy a cheap crank, use kb251 pistons with open chamber heads; instant 87 octane 493.
