70 Road Runner going from drum to manual disc brakes
#2084846
06/02/16 09:35 PM
06/02/16 09:35 PM
Posts: 204 Panama City, FL
rickinpc
Panama City, FL
Can anyone provide a workable combination of master cylinder and proportioning valves to make this work? Send a link to rtoalson@me.com or call 850-866-0909. Any help would be appreciated.
Rick
Re: 70 Road Runner going from drum to manual disc brakes
[Re: rickinpc]
#2084881
06/02/16 10:32 PM
06/02/16 10:32 PM
Posts: 4,223 ohio
ruderunner
ohio
I did my 69 decades ago. I used the large bore Mopar performance master and a Willwood adjustable valve
Angry white guy
[Re: rickinpc]
#2084896
06/02/16 10:59 PM
06/02/16 10:59 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I did the conversion on my barracuda years ago and used a 1978 dodge pickup manual disc brake master cylinder. I also used a Willwood proportioning valve
[Re: rickinpc]
#2085051
06/03/16 06:54 AM
06/03/16 06:54 AM
Posts: 9,982 Oakdale CT
gdonovan
Oakdale CT
I converted my GTX over to the big 11.75" rotors, big piston slider calipers last year. It also has 11" drums out back.
Left the prop valve alone, even under hard breaking it stops even with no lockup of any particular end. The car can stop fast enough now that it will uncover the oil pickup and flash the Autometer warning light with 20 psi sender which never happened with the drums.
I need to fool about with the master, I think I had a 7/8 unit which was too soft and now I have a 1 1/8 unit which is a touch on the hard side. Have not had a chance to tinker with it further and it does work pretty good. Pads are a Wagner semi-metallic police application.
"I think its got a hemi"
