1970 V code road runner dash wiring help #2081381
05/27/16 05:01 PM
05/27/16 05:01 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
I am putting together my 70 RR V code 4 speed car which was taken apart many years ago. Working on the under dash wire harness which as far as I know is original to the car when built.
The wires with the eyelets blue with white tracer and light green I am not finding a use for? shown in the image. I hooked them to a circuit breaker but that doesn't seem to be correct. with the wires connected together the headlights stay on when the head lamp switch is off and the ignition key in the run position.
The plug in the center of the 2 wires is for the flasher.
The amp gauge and other dash switches work.
Yes I have a service manual for the car and have searched for more info. with no luck. Any ideas?
Re: 1970 V code road runner dash wiring help [Re: Rodney] #2081404
05/27/16 05:36 PM
05/27/16 05:36 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't have the FSM here, but do you have unusual options like convertible top or power locks?
Re: 1970 V code road runner dash wiring help [Re: 451Mopar] #2081412
05/27/16 05:46 PM
05/27/16 05:46 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
no power accessories it does have the wire to the solenoid for the center carb. one of those things that will bug me until I understand what they are for. or how to terminate them they way the should be?
Re: 1970 V code road runner dash wiring help [Re: Rodney] #2081436
05/27/16 06:57 PM
05/27/16 06:57 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Looks like some very nice Bentley level body and paint work. Black's tough.
Re: 1970 V code road runner dash wiring help [Re: Rodney] #2081451
05/27/16 07:30 PM
05/27/16 07:30 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
I did it all :} tons of hours but worth it.
big long fairing boards and don't prime it until it is ready {straight}.
Re: 1970 V code road runner dash wiring help [Re: Rodney] #2081849
05/28/16 02:38 PM
05/28/16 02:38 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Pretty sure those wires or for 70 Charger only and are for the headlamp door relay. You will have to double check this.....from memory only. Good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1970 V code road runner dash wiring help [Re: Rodney] #2081865
05/28/16 03:39 PM
05/28/16 03:39 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Do you have the full sweep speedometer dash? Those terminals aren't in a Rallye Dash Harness. The light green pigtail is on the power wire from switched on headlights to floor dimmer switch circuit. The blue with white tracer pigtail is on your Ignition 1 circuit. Don't connect these together. Farther to the left of your pic you can see light green wires in a female bullet pigtail. That is the connection for the Charger headlight door relay.
Re: 1970 V code road runner dash wiring help [Re: Rodney] #2081943
05/28/16 06:49 PM
05/28/16 06:49 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
ok thanks that explains it. the dash harness must have been swapped out at some point before I purchased the RR.
all of the other gauges work and everything else seems to fit ok.
I will shrink tube and tie them up out of the way.
back glass installed using a 3/8 tape
Re: 1970 V code road runner dash wiring help [Re: Pynzo] #2081944
05/28/16 06:55 PM
05/28/16 06:55 PM
Central Oregon
Rodney Offline OP
Rodney  Offline OP
Central Oregon
rally dash 150 speedometer
