O-ring size for the power steering pressure hose? #2081511
05/27/16 09:38 PM
05/27/16 09:38 PM
VA
AtomicDog Offline OP
VA
I'm replacing the power steering gearbox on a 1973 Duster. I'm re-using the pressure hose and noticed that the O-ring that is typically on the end of the power steering gearbox end of the hose is missing. Does anyone happen to know what the size of the O-ring is so I can pickup a replacement O-ring? Also, who tends to carry this particular O-ring in stock?
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2081630
05/28/16 01:13 AM
05/28/16 01:13 AM
not sure if McMaster-Carr does or Grainger but here is a BTT for ya. EDIT Or FirmFeel
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2081662
05/28/16 02:29 AM
05/28/16 02:29 AM
VA
VA
I was trying to find one locally, if possible. Figured that someone on this forum might likely know what size the O-ring is to keep me from having to remove the hose from the pump. Thanks for the bump.
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2081669
05/28/16 03:09 AM
05/28/16 03:09 AM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
yes any hardware store or napa will have the correct size o-ring. o-rings are sized by a number. I cant remember offhand what the exact one you need is. I had called steer and gear and they told me exactly what size to get.
I know thats not much help
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2081746
05/28/16 11:01 AM
05/28/16 11:01 AM
VA
VA
Thanks for the info. Wish Steer + Gear was open today. Does anyone recall what size O-ring I need?
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2081863
05/28/16 03:36 PM
05/28/16 03:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Is the hose installed? if not take it with you and get the correct one. Or try your local dodge dealer.
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2081926
05/28/16 05:51 PM
05/28/16 05:51 PM
VA
VA
Yes, the hose is installed. I was trying to avoid removing it from the pump.
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2082595
05/30/16 12:51 AM
05/30/16 12:51 AM
VA
VA
Anyone?
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2082794
05/30/16 01:25 PM
05/30/16 01:25 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
are you sure there is supposed to be one? don't know about A bodies but my RR doesn't have o rings in the hose.
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2082871
05/30/16 03:48 PM
05/30/16 03:48 PM
VA
VA
Interesting thought. I've always seen them on the end of the power steering high pressure hoses in the past. When I removed it from the old steering gearbox, I did not see it and assumed that it got lost.
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2082880
05/30/16 03:58 PM
05/30/16 03:58 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
same theory as brake lines. maybe somebody at some point jammed one in there to try and stop a leak but i've never seen one come that way.
Re: O-ring size for the power steering pressure hose? [Re: AtomicDog] #2083206
05/31/16 01:03 AM
05/31/16 01:03 AM
VA
VA
I believe I figured out the O-ring size for the high pressure power steering hose end that goes into the steering gear - the steel end of the hose measured out to be 1/4" in diameter. I forgot that I had an O-ring assortment in the garage and when I checked closer, a R-05 O-ring fit it perfectly.
