Page 2 of 6 1 2 3 4 5 6
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074894
05/17/16 01:09 AM
05/17/16 01:09 AM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Also I've seen a lot of things in my life, but never, NEVER had I ever had all the exhaust manifold bolts come out without a hitch! Guess VC leaks were a good thing in my engines case. To quote Spock.. "Fascinating".
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074899
05/17/16 01:27 AM
05/17/16 01:27 AM
Washington
madscientist Offline
Washington
Originally Posted By DARTH V8R
@ qwkmopardan ~ thanks for the info. Didn't think those "smogger" heads had enough flow for a 9 second pass. Nice combo BTW.
@ thumperdart you bet buddy :thumb: & duly noted wink expect a package later on smile
Solid rollers question: I know they are spendy, but PITA to install & clearance or pretty straight forward? Thanks.
Pretty straight forward on SRL install.
I question the head deal myself. But, and this is a big butt, to go 9's in a 3100 pound car takes about 595 HP and in the correct combo any Pcar head can do that.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074903
05/17/16 01:34 AM
05/17/16 01:34 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If you buy the right lifters there shouldn't be any grinding.
I've seen Dan's stuff run, there is no bs there, it runs hard.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074904
05/17/16 01:39 AM
05/17/16 01:39 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am going to lurk in the background on this thread because last Monday I bought a 360 in pieces from a guy on Craigslist. It was a 1990 roller cam engine, the block was standard bore and had been hot tanked but not bored, the heads had been rebuilt and came with a Delta Cam regrind (new). The crank seems to be standard, but I also have a fresh .010/.010 stock stroke crank. It also had a truck pan and factory windage tray. He gave me a new mini-starter with it and some other scrap iron, intake & exhaust manifolds. So I think it was worth the $150.00 I paid for it. It will go in the DD when it is done.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074915
05/17/16 02:21 AM
05/17/16 02:21 AM
Its a TRAP!
Its a TRAP!
Well that's good to know the Pcar heads can get up and boogie! What kind of compression are you guys getting away with on an iron headed with 92oct E10 swill?
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074920
05/17/16 02:32 AM
05/17/16 02:32 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've still got the roller lifters from our 340 based mill... dropped right in, no grinding or oil hole uncovering issues. Think I still have the camshaft too...
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2074934
05/17/16 03:29 AM
05/17/16 03:29 AM
Washington
Washington
11.08:1 on pump gas.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075022
05/17/16 11:27 AM
05/17/16 11:27 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
I have comp 828-16s in a 76 model 360 block. They are close but no grinding was needed. I did need to tube the block though because they were uncovering the oil holes.
68 Barracuda Formula S 340
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075228
05/17/16 05:10 PM
05/17/16 05:10 PM
Its a TRAP!
Its a TRAP!
All righty I like the idea of 11:1 on pump gas with iron heads. Nothing like smoking aluminum headed BBC's with an iron headed engine.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075256
05/17/16 06:02 PM
05/17/16 06:02 PM
Washington
Washington
I haven't got it in the car yet. It's on the run in stand now and runs, just dealing with a pissy carb right now.
Was going to dyno it but I'm just burning out in the deal and it may go straight to the car.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075308
05/17/16 08:01 PM
05/17/16 08:01 PM
Its a TRAP!
Its a TRAP!
Roller cam? What kind of timing are you running with the iron heads?
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075312
05/17/16 08:11 PM
05/17/16 08:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With my 416 and W-2 iron heads I am running 10.6 compression
and 36* of timing.. its a decent size roller cam 260/270 on
a 105 LSA installed on 105.. that with .640/.640 lift... on
the street I run 87 octane.. I will run 93 at the track... I
get on it pretty good on the street with the 87 and no issues
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075327
05/17/16 08:32 PM
05/17/16 08:32 PM
Washington
Washington
SFT with 255 @ .050 with .620 lift gross 105 LSA installed on a 105 ICL and I'm locked out at 35* total.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075567
05/18/16 01:47 AM
05/18/16 01:47 AM
Its a TRAP!
Its a TRAP!
Mr P.. given her on the street 10.6 & 87 oct? Are those W2 chambers that good?
Thanks for the info mad!
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075682
05/18/16 10:23 AM
05/18/16 10:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They arent bad.. but I also have a .039 quench which
is a help... I also touch up the chambers so there isnt
any hot spots.. that was real quick with a tootsie roll
wave
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075724
05/18/16 11:24 AM
05/18/16 11:24 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
OK.... maybe I'm "elevation handicapped", but I'd stick to the plan of the Indy top end. I'm thinking you'll find it easier to meet your ET goal.
Re: FINALLY got me a 360.. [Re: J_BODY] #2075754
05/18/16 12:06 PM
05/18/16 12:06 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
I'm hearing ya. I was sure w/iron heads that there would have to be a quench dome.
[img] [/img]
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075758
05/18/16 12:11 PM
05/18/16 12:11 PM
P
Porter67 Offline
Porter67  Offline
P
You can mill the iron heads to have quench and a small chamber, combined with a piston like the wiseco +8 domed is a good combo but limits lift to .660 or so.
Re: FINALLY got me a 360.. [Re: J_BODY] #2075894
05/18/16 03:27 PM
05/18/16 03:27 PM
Its a TRAP!
Its a TRAP!
No doubt. Just fascinated that P-car Iron heads can go that fast.
Re: FINALLY got me a 360.. [Re: DARTH V8Я] #2075929
05/18/16 04:16 PM
05/18/16 04:16 PM
P
Porter67 Offline
Porter67  Offline
P
This pic is from RJ and these are far from ideal imo as well your fast iron heads are not going to look near oem except from a visual standpoint.
Look back at the days of mastic, who needs a 3d printer to make things with that stuff.
Why they would do this with oem valve use in mind...hmmm... not ideal.
