Re: 440 source stroker
[Re: oldtimer5151]
#2080241
05/25/16 08:35 PM
05/25/16 08:35 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
So a word to the wise, be sure to check all products from ANY AFTERMARKET SUPPLIER, or you will be in my situation. Fixed
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: oldtimer5151]
#2080261
05/25/16 09:22 PM
05/25/16 09:22 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
[quote+ I was informed that the end user was responsible to inspect all dimensions and return the defective product to be re-worked. [/quote]
They are correct.
Seriously doubt that any vendor would give any considerations on a part that failed due to the assembly. They can't control the end user's assembly errors.
Plastigage on ANY motor??? Uhh, NO.
[Re: oldtimer5151]
#2080264
05/25/16 09:28 PM
05/25/16 09:28 PM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
440 source would not replace or discount any amount on another stroker kit. Please tell me you can't be serious. There are many, many reasons for a bearing to spin. Any and all clearances have to be checked whether its a stock type of rebuild or high performance. It takes me hours to properly clean and prep a block before I start assembly. If unsure of yourself leave the job to a professional as its harder than it looks.
[Re: oldtimer5151]
#2080337
05/25/16 11:12 PM
05/25/16 11:12 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Only good things to say about 440 source from me, 9.20's @ 145 in my 63 Plymouth, belted piss out of it and even split a block but stroker kit still lives. Just ordered some parts from them and 5 days later I had them in Australia.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: oldtimer5151]
#2080378
05/25/16 11:49 PM
05/25/16 11:49 PM
Posts: 8,896 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I was informed that the end user was responsible to inspect all dimensions This is just common sense. I doubt that I'm the only one that takes brand new things apart, checks them and cleans them before reassembling for use. Had you bought a crate motor then I'd say "maybe" you'd have a leg to stand on but even then they'd probably say that racing voids any warranty. You've obviously got an axe to grind - you could just as easily have left their name out of the post. But most people seem to be taking their side, and rightly so.
[Re: Stanton]
#2080398
05/26/16 12:02 AM
05/26/16 12:02 AM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't care how much you pay for parts they have to be checked with the proper tools (not plastic gauge) I paid 2200 dollars for a Callas crank From Dan (Performance Only) years ago that was shipped directly from Indy Cylinder Head. I also ordered bearings from Dan when I placed the order. Dan never touched the crank as it was drop shipped from Indy. Imagine my surprise when I miced the crank and my "brand new" 2200 dollar crank was cut .010 on the rods. Did I send it back? NO because I really needed it and didn't want to deal with Indys crappy service. ALL PARTS MUST BE CHECKED!!!!!!!!!!!!!!!!
[Re: oldtimer5151]
#2080442
05/26/16 01:04 AM
05/26/16 01:04 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
So you said you checked all the main and rod bearing clearances with plastic gauge. I can't say it is accurate or not but it is close. I have used it in the past without a problem . I guess the question is: what clearance did you have when you measured on the rods, on the mains?
[Re: Stanton]
#2080464
05/26/16 01:58 AM
05/26/16 01:58 AM
Posts: 20,192 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm wondering how many millions of engines are out there that had plastigauge used to check clearances !!! Not everyone can afford or justify the cost of the tools. And a lot of them run for years too. Trouble is race engine clearances should be opened up some and the proper oil viscosity used. After-market cranks also have a heavy radius instead of an under-cut like stock cranks. Careful attention has to be used and the proper bearings for this application. Lots of guys don't know how to properly "set" the thrust bearing and just throw things together. I'm self taught so I know I've made lots of mistakes over the years and try to continue to learn something new every day. Lots of bad info floating around the internet forums. 40 plus years of engine building for me with 3 engines on my stands right now and another 2 in our race cars and I'm still learning and still buying tools.
