Re: I Did the speedo Calibration [Re: MR_P_BODY] #2082941
05/30/16 06:07 PM
05/30/16 06:07 PM
MR_P_BODY Offline OP
No more leaks.. ran REAL strong... but I forgot to
open the dumps.. again... no fuel issue this time and
I didnt change anything... I pulled to to higher revs
and it likes it... only went to 7500rpm... went nice
and straight also.. looks like the pre load is close
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2083727
05/31/16 11:20 PM
05/31/16 11:20 PM
I found my fuel issue today by accident ..as a buddy and
I we cruising to a show(just a place to go) my throttle
started hanging up at about 1400 pm.. when I got to the
show I open the hood and pulled the air cleaner... the throttle
linkage had a pit of play.. that was fine.. then I notices the
primaries are open a fair bit..way more than normal.. looking
around I see the throttle pressure cable came loose and the collar
on it was holding the blades open.. I put it back together the
way it should be adjusted and it idled fine.. on the way back
home I got on it HEAVY... ran great... if not better.. all I can
assume is the blades hanging up and the AIS were getting stupit
readings and some how shutting down fuel..or something... I tried
it 4 times on the way home(beating on it).. perfect each time
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2083748
05/31/16 11:52 PM
05/31/16 11:52 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Sounds like your getting the bugs worked out, nice looking hot rod!
Re: I Did the speedo Calibration [Re: gtsdude] #2083800
06/01/16 01:01 AM
06/01/16 01:01 AM
Thanks... its getting there... a couple of small issues
yet
wave
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2083928
06/01/16 09:42 AM
06/01/16 09:42 AM
moparx Offline
moparx  Offline
yet
wave
glad it's small items now instead of the other issues you have had to conquer.
beer
Re: I Did the speedo Calibration [Re: MR_P_BODY] #2083979
06/01/16 12:01 PM
06/01/16 12:01 PM
Az
Crizila Offline
Crizila  Offline
Az
I got it all back together today so the leaks should be
all fixed..I'll pull the vent line next time out.. I
should say the rollover valve and the vent line.. and
I'll open the dumps... just curious
wave
Have you run any crankcase pressure checks? Running a PCV system or just venting to atmosphere? ME Wagner makes an adjustable PCV valve ( both for idle and cruise )if you decide to go that route. Could be a leak fixer.
Fastest 300
Re: I Did the speedo Calibration [Re: Crizila] #2084028
06/01/16 01:14 PM
06/01/16 01:14 PM
wave
Just breathers right now.. no I havent done any vac readings
yet... that leak was my own fault.. when the tittie broke
off and I was tightening the pan.. I seen the front seal
moving forward.. I didnt think it was gonna be a issue...
I was wrong... the hole that the tittie should have been
in was where the oil was coming out of... I will hook up
a compound gauge to see what I have in there.... if I want
to run a PCV I would have to mod the air cleaner.. but I
want a new air cleaner with the 2 inlets with the hoses
EDIT
I'm thinking about making some changes to the engine..
it lopes big time and I'm not thrilled with all the
tappet noise and I have them tighter than spec.. that roller
might go.. also thinking of a change with the heads.. I
might put the W-5s back on... or pick up some new heads..
I just dont know yet
wave
