Re: Easiest way to pull a van motor ... in a boneyard...
[Re: Sixpak]
#2079132
05/24/16 12:19 AM
05/24/16 12:19 AM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
When I have done it I look for one with no trans, pull the heads and let the short block fall out from underneath, just make sure you are not under the engine when you unbolt the mounts.
[Re: Sixpak]
#2079237
05/24/16 10:30 AM
05/24/16 10:30 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Would it be worth it to buy the whole van, yank the motor at home, then haul the carcass back for scrap?
**Photobucket sucks**
[Re: Sixpak]
#2082153
05/29/16 02:44 AM
05/29/16 02:44 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
I would wait and find another vehicle like a pickup or passenger car.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
