Re: lifter valley plate for trick flows
[Re: BradH]
#2078469
05/22/16 09:57 PM
05/22/16 09:57 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Why not one piece? make the ports standard size, and leave material around the ports for end user fitment. Since you don't like his design, why not try building something yourself, instead of complaining about what Andy's coming up with on his own? You already described what you'd like to see made. I have made what I describe. That's my whole point. It is very easy if you have the equipment. From the parts he's shown, its obvious that he could make one. I was trying to stay out of the selling aspect, but if someone needs one made just pm me. All I would need is a couple of simple measurements for anything that is not factory deck ht.
[Re: TRENDZ]
#2078514
05/22/16 11:17 PM
05/22/16 11:17 PM
BradH
Why not one piece? make the ports standard size, and leave material around the ports for end user fitment. Since you don't like his design, why not try building something yourself, instead of complaining about what Andy's coming up with on his own? You already described what you'd like to see made. I have made what I describe. That's my whole point. It is very easy if you have the equipment. From the parts he's shown, its obvious that he could make one. I was trying to stay out of the selling aspect, but if someone needs one made just pm me. All I would need is a couple of simple measurements for anything that is not factory deck ht. Pics?
[Re: Jimbo]
#2078518
05/22/16 11:27 PM
05/22/16 11:27 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Hey Andy, I love your work and have used plenty of your tricks so I'm not being picky ok.
I made a ali valley tray for some 516 heads that I was using on the track years ago, the problem I had was the thin (1.2 mm about .050)tray broke it' seals on the front and rear of the engine because of vibration. I think your idea will need the flat bars each end and you will need to look at the join. Cheers Al
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Jimbo]
#2078691
05/23/16 09:20 AM
05/23/16 09:20 AM
TRENDZ
Milwaukee WI
I don't have pics of the part not on the engine. The engine had the intake ports moved up .750", so no off the shelf pan would work. I'm not digging on Andy. His stuff is all top notch, and were I building another BB, he would be on speed dial. I just look for the simplest solution.
[Re: moparx]
#2078807
05/23/16 01:47 PM
05/23/16 01:47 PM
Posts: 31,076 Oregon
AndyF
The two piece design is adjustable. I can build a one piece design for my own engine but I wouldn't sell it as a product since I'd get an endless stream of complaints. People build engines with blocks that have been decked or with different head gaskets or with heads that have been milled but then blame me when the valley tray doesn't fit.
The two piece design has slots so it can slide back and forth to adjust for different deck heights, different head gasket thicknesses and different cylinder head heights. would there be a stiffening of the two piece if you incorporated a 90*flange approximately 3/8" into the lifter valley on the lower piece ? notching for the china walls of course. or would this be of little benefit ? That actually seems like a good idea. By turning one edge down you would make the part stiffer.
[Re: AndyF]
#2079768
05/25/16 02:00 AM
05/25/16 02:00 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
The two piece design has slots so it can slide back and forth to adjust for different deck heights, different head gasket thicknesses and different cylinder head heights. How about one for me??
Brian Hafliger
[Re: Jimbo]
#2079806
05/25/16 04:42 AM
05/25/16 04:42 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
didn't Hughes or someone have a 2 piece tray ? was a lot of complaints of leakage at overlap . that may be the hardest area to seal ? maybe the folded edge will help this by being stiffer . maybe have a threaded bar spot welded to the plate rather than use sheet metal screws at least then they wont tear out
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Brian Hafliger]
#2079958
05/25/16 12:39 PM
05/25/16 12:39 PM
AndyF
The two piece design has slots so it can slide back and forth to adjust for different deck heights, different head gasket thicknesses and different cylinder head heights. How about one for me?? You want a one piece design or a pair of the two piece? I can send you some prototype parts if you want. Some fitting may be required......
[Re: Jimbo]
#2082012
05/28/16 09:21 PM
05/28/16 09:21 PM
Posts: 810 Sidney Ohio
9SecRoadRunner
Sidney Ohio
I didn't read all the posts so I'm not sure if this has been suggested, But what I did was get some sheet gasket material, cut out my own intake gaskets leaving an extra 3/8" on the bottom, then I scored it along that extra 3/8" and folded up making like an "L" shape along the bottom, it sat right on the indy plate ... a little sealer and it worked (so far).....
You Thinking It's So Doesn't Make It a Fact
