Page 6 of 6 1 2 3 4 5 6
Re: SB VICTOR ready for Dyno [Re: pittsburghracer] #2079076
05/23/16 09:39 PM
05/23/16 09:39 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Originally Posted By pittsburghracer
Originally Posted By HotRodDave
I am not saying a magnum block is a race block but it is a simple fact it is much stronger than an LA 360-340-318-273 except possibly a 340TA block. I made a big thread showing some of the differences I am aware of and they are not insignificant.
As for detonation tolerance I am running 11.5 with stock ported by me iron magnum heads and a tiny 221@.050 cam 91 octane and ZERO sighns of detonation, try that with some dinosaur open chamber LA heads.
I would sure like to see proof of this but I never see any FAST magnum small blocks out there.
You will here real soon I promise.....
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: SB VICTOR ready for Dyno [Re: Jason B] #2080779
05/26/16 04:05 PM
05/26/16 04:05 PM
Mopar
Jason B Offline OP
Jason B  Offline OP
Mopar
1968 Cuda 440" Edelbrock Victor Head Small Block.
[img]https://board.moparts.org/ubbthreads/upload4/23859.png[/img]
Re: SB VICTOR ready for Dyno [Re: Jason B] #2081112
05/27/16 02:03 AM
05/27/16 02:03 AM
SoCal
Brian Hafliger Offline
SoCal
Are the cam specs a secret???
Brian Hafliger
Re: SB VICTOR ready for Dyno [Re: Jason B] #2081115
05/27/16 02:31 AM
05/27/16 02:31 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Man, why not run a Dommy on that thing? Good engine regardless.
Mopar to the bone!!!
Re: SB VICTOR ready for Dyno [Re: Brian Hafliger] #2081197
05/27/16 10:27 AM
05/27/16 10:27 AM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Brian, Like you don't know how to spec a cam smile
[img] [/img]
Re: SB VICTOR ready for Dyno [Re: clonestocker] #2081268
05/27/16 12:33 PM
05/27/16 12:33 PM
SoCal
SoCal
I only ask because they keep saying the cam specs are a bit compromised due to the rockers I'm guessing?
Just wondering how much the cam was specs were compromised...that is all!
The cam we'll be using for 434cid will be around 282-290@ .050 .830 lift and around 112lca...see no biggie!
Brian Hafliger
Re: SB VICTOR ready for Dyno [Re: Brian Hafliger] #2081288
05/27/16 01:18 PM
05/27/16 01:18 PM
Tucson, Arizona
Tucson, Arizona
[/quote]
The cam we'll be using for 434cid will be around 282-290@ .050 .830 lift and around 112lca...see no biggie! [/quote]
Those #'s make mine look timid lol
[img] [/img]
Re: SB VICTOR ready for Dyno [Re: Brian Hafliger] #2081442
05/27/16 06:04 PM
05/27/16 06:04 PM
slammedR/T Offline
slammedR/T  Offline
eek
racemagnum
Re: SB VICTOR ready for Dyno [Re: Jason B] #2086958
06/06/16 11:09 AM
06/06/16 11:09 AM
sst404b Offline
sst404b  Offline
We finally got to work on the Cuda this weekend and installed the engine.The engine is taller and wider so the headers hit the cage tubes. The vacuum pump hits the frame and when we moved it now hits the block,and the starter hits the block. Fitting starter was the easiest thing to fix,5 minutes of grinding fixed that, but I had to cut the headers and rework the two center tubes. The plan is to use these for now and have a new set build. The vacuum pump is on going. Hope to have it running this week. I'll have Jason post a few pics.
Ray
Re: SB VICTOR ready for Dyno [Re: Jason B] #2137151
08/20/16 10:12 AM
08/20/16 10:12 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
any updates?
Re: SB VICTOR ready for Dyno [Re: Jason B] #2137496
08/20/16 08:50 PM
08/20/16 08:50 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Is there a phone number for the machine shop that did all the work to the block
Re: SB VICTOR ready for Dyno [Re: Jason B] #2137633
08/21/16 01:03 AM
08/21/16 01:03 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: SB VICTOR ready for Dyno [Re: Jason B] #2137770
08/21/16 10:49 AM
08/21/16 10:49 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Thank you
