Re: SB VICTOR ready for Dyno
[Re: sst404b]
#2076658
05/19/16 06:53 PM
05/19/16 06:53 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
This is a throttle stop engine so peak will not be the same as an all out super stock or comp engine , but i agree needs a different cam and more carb The thought right now is we will see around 770 before we call it
Ray Did you ever say how big the engine is? I don't recall... Brian
Brian Hafliger
[Re: SS4446]
#2076694
05/19/16 07:38 PM
05/19/16 07:38 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Well since I'm done dynoing I'll report the results for the buckners and everyone else. We finished at 796hp@7400 and 689tq@5800. As Ray and Jason have stated this engine is built for a throttle stop and durability. I feel like with a different cam, a touch more compression, and a bigger carb 850+ is attainable. My dyno is a bit on the conservative side. My customer Steve Kent has a SS/AH car that we've been 8.20's with and on my dyno it makes 990hp compared to others making 1050+ that we run with or outrun usually. Just giving you guys some info. Thanks, Allen Allen, Did you used to go by J Allen Sherman. Bought my stocker lifters from you about 12 years ago. Glad to see you still digging hard. Did notice that are still hitting some Natl events and so on. Good Job on this build. matt btw: Welcome to MOPARTS
[img] [/img]
[Re: Jason B]
#2076703
05/19/16 07:49 PM
05/19/16 07:49 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Yeahhhhh!!! Really nice results... Thanks for share this build with us! Finally a real SB Mopar OOTB Heads!
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
[Re: Jason B]
#2076723
05/19/16 08:16 PM
05/19/16 08:16 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
^^^ Thanks for the info Great #'s too!
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2076732
05/19/16 08:23 PM
05/19/16 08:23 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks for the post and the info. After seeing them on the drawling board for so long its great to see that with some work they deliver as promised.
