Re: SB VICTOR ready for Dyno
[Re: Jason B]
#2075900
05/18/16 03:34 PM
05/18/16 03:34 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
How about some details on the motor?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: Jason B]
#2075990
05/18/16 05:47 PM
05/18/16 05:47 PM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
Big MPH for a S/ST car. Cannot wait to see the results!!
[Re: MR_P_BODY]
#2076085
05/18/16 08:29 PM
05/18/16 08:29 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
Looks good, good luck with it! Your the first that I know of that will have an engine running with these heads.
TD called today to let me know those heads will work with 48° blocks as well...
Brian Hafliger
[Re: Jason B]
#2076098
05/18/16 08:58 PM
05/18/16 08:58 PM
Posts: 4,457 Washington
madscientist
Washington
Hey, The dude that did your intake has his stuff wired tight.
If I was a betting man, I'd bet my bottom dollar he gained you a fat 20 HP everywhere, and probably more.
Very VERY nice work. I wish you had an off the shelf manifold to do back to back testing.
Now that it look at it again, I'd bet 30 HP everywhere and more than that at peak.
[Re: Jason B]
#2076101
05/18/16 09:05 PM
05/18/16 09:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The rockers actually measured 1.6 not sure why they wouldn't. Just a note they are not out of the box ready it took Allen 2 days of fitting and correcting clearance issues. If y'all have any issues give him a call he can get you everything you will need BB rockers are usually long on the stem side..they come real close to the outer edge of the stem...I had a set of mis marked SB rockers that were actually BB ones and that was how mine were anyways(they were Crane blue rockers) EDIT also whats the install height on your springs
[Re: madscientist]
#2076116
05/18/16 09:27 PM
05/18/16 09:27 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
Now that it look at it again, I'd bet 30 HP everywhere and more than that at peak. That's pretty damn good considering there's no CSA info about it! Wow...
Brian Hafliger
[Re: Brian Hafliger]
#2076127
05/18/16 09:59 PM
05/18/16 09:59 PM
madscientist
Washington
Now that it look at it again, I'd bet 30 HP everywhere and more than that at peak. That's pretty damn good considering there's no CSA info about it! Wow... I'd put my money on me being correct. I've seen those gains just from correcting the plenum. Even moreso with the Strip Dominator.
[Re: Jason B]
#2076149
05/18/16 10:31 PM
05/18/16 10:31 PM
Posts: 205 Edmonton Alberta, Canada
R3DART
Very nice. Cool to see all these new unchartered parts coming together.
Does anyone care to share their thoughts on how much more potential these heads have over a set of properly prepped 360-1 245's?
[Re: J_BODY]
#2076169
05/18/16 11:02 PM
05/18/16 11:02 PM
MR_P_BODY
Do these heads use a stock type intake or what... I see he has a victor intake but is that a stock bolt pattern or a W type bolt pattern
