Page 1 of 6 1 2 3 4 5 6
SB VICTOR ready for Dyno #2075896
05/18/16 03:30 PM
05/18/16 03:30 PM
Mopar
Jason B Offline OP
Jason B  Offline OP
Mopar
: dino Almost time to hook up to the Dyno thank you Allen Sherman at Trumble racing Engines let's see what this bad boy will do!!!
1968 Cuda 440" Edelbrock Victor Head Small Block.
[img]https://board.moparts.org/ubbthreads/upload4/23859.png[/img]
Re: SB VICTOR ready for Dyno [Re: Jason B] #2075900
05/18/16 03:34 PM
05/18/16 03:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
How about some details on the motor?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: SB VICTOR ready for Dyno [Re: Jason B] #2075952
05/18/16 04:36 PM
05/18/16 04:36 PM
sst404b Offline
sst404b  Offline
Ritter block 4.185 x 4.0
Victor heads OOTB with clean up and valve job
60 mm cam .480 int .460 exh 1.6 rockers
Houghes big block victor rockers with fit spacers
1000 cfm throttle stop carb
15 to 1 comp
intake flow is 380 at .800
This is going in a super street 69 Barracuda 2800lb w/driver
looking for 10.90 @ 145 to 150 mph
It is being build by Allen Sherman at Trumble Racing
Re: SB VICTOR ready for Dyno [Re: Jason B] #2075976
05/18/16 05:15 PM
05/18/16 05:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I have finaly seen a unicorn!
Sweet piece, hope it runs real good,as it should!
Re: SB VICTOR ready for Dyno [Re: sst404b] #2075982
05/18/16 05:27 PM
05/18/16 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
15 to 1 comp
Should run that pretty easy... how many revs are you planning on
wave
Re: SB VICTOR ready for Dyno [Re: Jason B] #2075990
05/18/16 05:47 PM
05/18/16 05:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Big MPH for a S/ST car. Cannot wait to see the results!!
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076025
05/18/16 06:44 PM
05/18/16 06:44 PM
sst404b Offline
sst404b  Offline
The old W2 416 ran 10.90 @ 135-138 so using the numbers we think it should be in that 145-150 range. We did dyno the 440 with the W2 heads and made just under 700hp which was about 60 better then the 416 was,that is when we decided to try another head. The W2 intake flow was 316 @650 and was done, the Victors are still going at 800.We don't plan to run it past 7500 rpm because of the valve train.
Ray
Re: SB VICTOR ready for Dyno [Re: sst404b] #2076032
05/18/16 06:55 PM
05/18/16 06:55 PM
AndyF Offline
AndyF  Offline
What is the actual measured rocker arm ratio on the engine? I know that the SB heads struggle to get decent rocker arm ratio so I'm wondering what you ended up with those heads and rocker arms.
Re: SB VICTOR ready for Dyno [Re: AndyF] #2076052
05/18/16 07:31 PM
05/18/16 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I see you said BB rockers.. I'd like to know how well
they fit on that head
wave
Re: SB VICTOR ready for Dyno [Re: MR_P_BODY] #2076085
05/18/16 08:29 PM
05/18/16 08:29 PM
SoCal
Brian Hafliger Offline
SoCal
Looks good, good luck with it! Your the first that I know of that will have an engine running with these heads.
TD called today to let me know those heads will work with 48° blocks as well...
Brian Hafliger
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076093
05/18/16 08:45 PM
05/18/16 08:45 PM
Mopar
Jason B Offline OP
Jason B  Offline OP
Mopar
The rockers actually measured 1.6 not sure why they wouldn't. Just a note they are not out of the box ready it took Allen 2 days of fitting and correcting clearance issues. If y'all have any issues give him a call he can get you everything you will need
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076096
05/18/16 08:54 PM
05/18/16 08:54 PM
Mopar
Jason B Offline OP
Jason B  Offline OP
Mopar
Here is the intake work Allen did on the super victor
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076098
05/18/16 08:58 PM
05/18/16 08:58 PM
Washington
madscientist Offline
Washington
Hey,
The dude that did your intake has his stuff wired tight.
If I was a betting man, I'd bet my bottom dollar he gained you a fat 20 HP everywhere, and probably more.
Very VERY nice work. I wish you had an off the shelf manifold to do back to back testing.
Now that it look at it again, I'd bet 30 HP everywhere and more than that at peak.
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076101
05/18/16 09:05 PM
05/18/16 09:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BB rockers are usually long on the stem side..they come
real close to the outer edge of the stem...I had a set of
mis marked SB rockers that were actually BB ones and that
was how mine were anyways(they were Crane blue rockers)
EDIT
also whats the install height on your springs
wave
Re: SB VICTOR ready for Dyno [Re: madscientist] #2076116
05/18/16 09:27 PM
05/18/16 09:27 PM
SoCal
SoCal
Originally Posted By madscientist
Hey,
That's pretty damn good considering there's no CSA info about it! Wow...
Brian Hafliger
Re: SB VICTOR ready for Dyno [Re: Brian Hafliger] #2076127
05/18/16 09:59 PM
05/18/16 09:59 PM
Washington
Washington
Hey,
I'd put my money on me being correct. I've seen those gains just from correcting the plenum. Even moreso with the Strip Dominator.
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076130
05/18/16 10:03 PM
05/18/16 10:03 PM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Wow that thing looks good. So glad this head is finally coming to fruition
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076149
05/18/16 10:31 PM
05/18/16 10:31 PM
Edmonton Alberta, Canada
R3DART Offline
R3DART  Offline
Very nice. Cool to see all these new unchartered parts coming together.
Does anyone care to share their thoughts on how much more potential these heads have over a set of properly prepped 360-1 245's?
Re: SB VICTOR ready for Dyno [Re: Jason B] #2076166
05/18/16 10:55 PM
05/18/16 10:55 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
four years after they hit the catalog..... with a wait time like that it truly should have had a Mopar part number. Hoping for the best!!! I was so excited at the possibility of running these.
Re: SB VICTOR ready for Dyno [Re: J_BODY] #2076169
05/18/16 11:02 PM
05/18/16 11:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do these heads use a stock type intake or what... I
see he has a victor intake but is that a stock bolt
pattern or a W type bolt pattern
wave
