Re: SB VICTOR ready for Dyno
[Re: Jason B]
#2076181
05/18/16 11:18 PM
05/18/16 11:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I can see that there is a gap... like a air gap intake but is the both pattern like a W intake or stock.. they are different
[Re: MR_P_BODY]
#2076183
05/18/16 11:18 PM
05/18/16 11:18 PM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
note how high that intake sits P!! I cant make anything out in your pic look at the first pict in the post..... that sucker is UP there! ...looks higher than the W5 deal anyways.
[Re: J_BODY]
#2076185
05/18/16 11:19 PM
05/18/16 11:19 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
note how high that intake sits P!! I cant make anything out in your pic look at the first pict in the post..... that sucker is UP there! Looks close to 3/4
[Re: RAY1969CARS]
#2076187
05/18/16 11:24 PM
05/18/16 11:24 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
How did you get oil up to the back of the block.I have had 2 of these blocks and neither one had oil up there. Did you run an external oil line
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: RAY1969CARS]
#2076188
05/18/16 11:26 PM
05/18/16 11:26 PM
MR_P_BODY
But what is the bolt pattern.. they can cast that intake as high as they want but what is the bolt pattern.. in other words.. are those heads made for a certain manifold or will any stock intake work... or does a W series intake bolt on
[Re: Jason B]
#2076189
05/18/16 11:29 PM
05/18/16 11:29 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Subscribed! Good luck, can't wait to see the results.
[Re: MR_P_BODY]
#2076308
05/19/16 02:35 AM
05/19/16 02:35 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
But what is the bolt pattern.. they can cast that intake as high as they want but what is the bolt pattern.. in other words.. are those heads made for a certain manifold or will any stock intake work... or does a W series intake bolt on Bolt pattern is the same as a Victor 340, which is you typical LA style. Ports on the Super Victor is .1" smaller width and .1 increase in height. Ports raised 3/4" and carb height is +1.5" to the Vic 340.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: Jason B]
#2076458
05/19/16 01:10 PM
05/19/16 01:10 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The Super Victor is not 1.5" taller than the Victor. I just put one on my car and it is only 1/2 inch taller. I am still running a stock hood so this was a critical thing to keep an eye on.
I had to take a ton of material out of the super victor to match my ported Edelbrock RPM heads. I changed to much at one time to tell if it makes any more power than the Victor. I moved to EFI at the same time and only have one trip to the track so far.
68 Barracuda Formula S 340
[Re: Jason B]
#2076540
05/19/16 03:56 PM
05/19/16 03:56 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Just to report Its ALIVE and running on the Dyno the unicorn lives!! Run the dog $hit out of it!
Brian Hafliger
[Re: Jason B]
#2076549
05/19/16 04:03 PM
05/19/16 04:03 PM
Bad340fish
Tulsa OK
Great news! keep us posted
