Re: Fender Tag Decoder
[Re: JFChallenger440]
#2075315
05/17/16 08:20 PM
05/17/16 08:20 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
E63 on the bottom should be the engine code
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: BigMoneyLewis]
#2075370
05/17/16 09:33 PM
05/17/16 09:33 PM
Posts: 1,565 tennessee
pushbutton
tennessee
E63 is 383 hp It's a 1969 Road Runner W1 white with black vinyl top, automatic trans ,, v21 performance hood treatment , black bench seat , black inside upper door frame color , Red longitudinal pinstripe , Scheduled build date of June 2 1968
Greg VERY early 69!
[Re: pushbutton]
#2075385
05/17/16 09:58 PM
05/17/16 09:58 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Greg VERY early 69! TOO early , no 69 models were scheduled that early , that was still 1968 production. SPD is June 2 , 1969 , late ish production.
#2075393
05/17/16 10:12 PM
05/17/16 10:12 PM
JohnRR
U.S.S.A.
19161 Gate/base
286013 Body sequence number
9A285266 VIN sequence numbering ... last 8 of the cars VIN, this number also stamped on the body in 2 places .. rad support and the left side trunk rail under the weatherstrip
926 383 4bbl 335HP for auto trans
595 8.75 rear , 3.23 gears , sure grip , 11" drum brakes
93, 093, auto trans , last 2 digits of part number used
1X, V1X, black vinyl top
6R, V6R, sports strip , red , longitudinal tape W1, EW1, upper body paint White
W1, EW1, lower body paint White
M2X, H2X ?, Black vinyl bench seat , either low level or high level depending on the first letter.
X9, TX9, upper door frame paint color , black
V21 performance hood treatment
RM23 1969 road runner hardtop, first 4 of the cars VIN
E63 383 , 335HP
D32 HD automatic transmission
602 scheduled production date , June 2, 1969
156783 vehicle order number.
[Re: JohnRR]
#2075609
05/18/16 03:21 AM
05/18/16 03:21 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
John, as this is a hard top, I'm pretty sure it would be H2*. I think the M2* was coupe only.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#2075725
05/18/16 11:25 AM
05/18/16 11:25 AM
JohnRR
U.S.S.A.
John, as this is a hard top, I'm pretty sure it would be H2*. I think the M2* was coupe only. Thanks Doug , I didn't dig very deep to do that other than looking up what the exact rear code was and to confirm the stripe was tape and not painted on, rest I did from memory ...
