Soldering sending unit from fuel tank #2075082
05/17/16 01:05 PM
05/17/16 01:05 PM
Maryland
wally426ci Offline OP
Maryland
I need to Solder my sending unit, but wondering if there is a good way of cleaning all fuel residue so I don't end up in flames? Or a time for evaporation?
ozbbq
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2075147
05/17/16 02:56 PM
05/17/16 02:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I soldered mine when I made it 3/8s.Used my big soldering iron.But if its dry it should not light up as the gas will be gone.Just make sure its out of the tank.Rocky
Chrysler Firepower
Re: Soldering sending unit from fuel tank [Re: therocks] #2075178
05/17/16 03:48 PM
05/17/16 03:48 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have done the same with the unit out of the tank and no problem...just be careful with the heat because you can damage the sending unit with too much.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2075189
05/17/16 04:10 PM
05/17/16 04:10 PM
Maryland
Maryland
Thanks guys! funny rocks!
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2075276
05/17/16 06:47 PM
05/17/16 06:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't think there's an issue once the fuel has all dried off. Its actually gas "fumes" that ignite, not the liquid. Once good and dry there should be no issue even though the gas smell is still present.
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2075387
05/17/16 10:03 PM
05/17/16 10:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You should see my buddy weld tanks.He has done tons and never a problem.Starts the tow motor puts the exhaust in the tank lets it fill and away he goes.Been doing them for at least 45 years.First time I saw him I was out the door.Saw a tank blow once not a pretty sight.Almsot took my one friends arm when it blew staright up about 100 feet.Rocky
Chrysler Firepower
Re: Soldering sending unit from fuel tank [Re: therocks] #2075411
05/17/16 10:49 PM
05/17/16 10:49 PM
What Pete said, I'd be (way) more concerned about keeping the heat away from the windings. Would some clay/play doh etc around the hard line wick up heat??
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2075633
05/18/16 08:38 AM
05/18/16 08:38 AM
Maryland
Maryland
Good idea Robert.
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2075751
05/18/16 12:01 PM
05/18/16 12:01 PM
You could grab a tube of biscuits the next time you are grocery shopping, the tube that you smack on the table edge to pop it open. that'd save you from having to track down something (clay) that might not be readily available. (they are on sale regularly for 99 cents)
Re: Soldering sending unit from fuel tank [Re: RapidRobert] #2076035
05/18/16 07:00 PM
05/18/16 07:00 PM
dogdays Offline
dogdays  Offline
Good idea, he could also use wet paper.
This has nothing to do with welding a gas tank.
I'd suggest using a torch with a pointed flame, should be able to get the soldering done before everything gets too hot. Solder has different melting points depending on the composition, but it's around 400 degrees F. Red heat is quite a bit hotter than that.
Clean the area to be soldered and use the correct flux and it'll be OK.
R.
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2076087
05/18/16 08:31 PM
05/18/16 08:31 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
When I built my 3/8 inch unit I used a radio shack butane pencil flame torch and silver solder. I also used it to attach the sending unit to the tube. That was the hardest part. They use spot welds from the factory.
Re: Soldering sending unit from fuel tank [Re: wally426ci] #2076333
05/19/16 08:38 AM
05/19/16 08:38 AM
Maryland
Maryland
thanks for the additional comments!!
