Re: Soldering sending unit from fuel tank
[Re: wally426ci]
#2075147
05/17/16 02:56 PM
05/17/16 02:56 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I soldered mine when I made it 3/8s.Used my big soldering iron.But if its dry it should not light up as the gas will be gone.Just make sure its out of the tank.Rocky
Chrysler Firepower
[Re: therocks]
#2075178
05/17/16 03:48 PM
05/17/16 03:48 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I soldered mine when I made it 3/8s.Used my big soldering iron.But if its dry it should not light up as the gas will be gone.Just make sure its out of the tank.Rocky I have done the same with the unit out of the tank and no problem...just be careful with the heat because you can damage the sending unit with too much.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: wally426ci]
#2075387
05/17/16 10:03 PM
05/17/16 10:03 PM
therocks
Niles , Ohio
You should see my buddy weld tanks.He has done tons and never a problem.Starts the tow motor puts the exhaust in the tank lets it fill and away he goes.Been doing them for at least 45 years.First time I saw him I was out the door.Saw a tank blow once not a pretty sight.Almsot took my one friends arm when it blew staright up about 100 feet.Rocky
Chrysler Firepower
[Re: therocks]
#2075411
05/17/16 10:49 PM
05/17/16 10:49 PM
RapidRobert
What Pete said, I'd be (way) more concerned about keeping the heat away from the windings. Would some clay/play doh etc around the hard line wick up heat??
[Re: wally426ci]
#2075751
05/18/16 12:01 PM
05/18/16 12:01 PM
RapidRobert
You could grab a tube of biscuits the next time you are grocery shopping, the tube that you smack on the table edge to pop it open. that'd save you from having to track down something (clay) that might not be readily available. (they are on sale regularly for 99 cents)
[Re: RapidRobert]
#2076035
05/18/16 07:00 PM
05/18/16 07:00 PM
dogdays
Good idea, he could also use wet paper.
This has nothing to do with welding a gas tank.
I'd suggest using a torch with a pointed flame, should be able to get the soldering done before everything gets too hot. Solder has different melting points depending on the composition, but it's around 400 degrees F. Red heat is quite a bit hotter than that.
Clean the area to be soldered and use the correct flux and it'll be OK.
R.
