Page 2 of 4 1 2 3 4
Re: Place your bets, Dyno scheduled this Friday [Re: sgcuda] #2069826
05/09/16 01:14 AM
05/09/16 01:14 AM
Alberta
440_Offroader Offline
Alberta
I really don't have a clue, but I'll throw in some numbers. 636hp with the 750, and 661hp with the 950 carb.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2069849
05/09/16 01:47 AM
05/09/16 01:47 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
651hp
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2069852
05/09/16 01:51 AM
05/09/16 01:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
667hp
Mopar to the bone!!!
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2069862
05/09/16 02:09 AM
05/09/16 02:09 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I've seen too much variation from different dynos to guess what it'll make on an unknown one. On Dwayne's I'd think about 630 at 6800 and 555 torque at 5400. The QFT 950 is probably worth 10 HP over the 750 you have.
Whatever it's going into better have at least a 5K stall converter and enough gear to keep the RPM up above 6K most of the time.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2069940
05/09/16 10:26 AM
05/09/16 10:26 AM
Alberta
Wookie316 Offline OP
Alberta
8" 5400 stall. 4.30 gear. The Dyno it is going on is the same one my 511 went on. When I showed Dwayne the sheet from that I believe he thought it was about 20 HP higher than the #'s he'd see on his. So maybe it will go 640-650?
I thought the 511 if it nosed over 700 it would just do it. It made 743.
I like to guess low then I'm not bumbed out if it don't make that.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2070164
05/09/16 04:18 PM
05/09/16 04:18 PM
I'm going to guess 550 to 575 HP with a little less torque.
Re: Place your bets, Dyno scheduled this Friday [Re: Cab_Burge] #2070167
05/09/16 04:30 PM
05/09/16 04:30 PM
fresno ca
mikeysmopars Offline
fresno ca
615 twocents
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Place your bets, Dyno scheduled this Friday [Re: mikeysmopars] #2070217
05/09/16 06:00 PM
05/09/16 06:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
575 to 600 hp tops. The 750 carb and 260 @ .050 will be the limiting factors, imo.
Re: Place your bets, Dyno scheduled this Friday [Re: CSK] #2070284
05/09/16 08:22 PM
05/09/16 08:22 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By csk
651hp
Revising mine from 650 to 652!
Fastest 300
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2070296
05/09/16 08:51 PM
05/09/16 08:51 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
This will make massive torque...
I'll say 639hp and 615lbs tq
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2070315
05/09/16 09:20 PM
05/09/16 09:20 PM
Alberta
Alberta
My 511 when it had 11.3-1 CR and a little smaller cam than the one in my 440 made 655 HP @ 5900 with a 1 7/8x3 header. The heads off that 511 are now on this 440. This engine will be Dyno'd on same dyno. I have my buddy's 950 QTP, so it could go 650 + with that 950 and a 1" spacer and a 2x3.5 header?
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2072474
05/13/16 09:32 AM
05/13/16 09:32 AM
Alberta
Alberta
On my way to have engine Dyno'd. Should have #'s by this afternoon. Stay tuned.
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2072520
05/13/16 11:12 AM
05/13/16 11:12 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Good luck and keep us updated.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2072532
05/13/16 11:38 AM
05/13/16 11:38 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
What the heck. Here goes 611hp. Our dragster motor is not far off from what you have. Pump gas -1 with minimal work done. Small roller makes 650ish
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2072555
05/13/16 12:36 PM
05/13/16 12:36 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My guess is 628 hp
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2072641
05/13/16 03:16 PM
05/13/16 03:16 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I have a Ray Murray 850cfm carb for sale if you are interested in getting that motor breathing wink
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Place your bets, Dyno scheduled this Friday [Re: Eric] #2072663
05/13/16 03:40 PM
05/13/16 03:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Would hardly call an 850 "breathing" just saying............ whistling I run those on most small blocks and dommys on big blocks myself............Sorry, 650 hp similar tq............
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2072714
05/13/16 04:44 PM
05/13/16 04:44 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
850 is quite a bit bigger than a 750...actually bigger than a 950 correct?
Re: Place your bets, Dyno scheduled this Friday [Re: Eric] #2072761
05/13/16 05:30 PM
05/13/16 05:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Bigger than a 750 and SOME so called 950`s yes but no match for a good running BB imo.............
Re: Place your bets, Dyno scheduled this Friday [Re: Wookie316] #2072764
05/13/16 05:37 PM
05/13/16 05:37 PM
Las Vegas
Las Vegas
Heck we have a Domionator on the truck motor in the Dragster smile
Page 2 of 4 1 2 3 4
