Re: Place your bets, Dyno scheduled this Friday
[Re: Wookie316]
#2069862
05/09/16 02:09 AM
05/09/16 02:09 AM
BradH
I've seen too much variation from different dynos to guess what it'll make on an unknown one. On Dwayne's I'd think about 630 at 6800 and 555 torque at 5400. The QFT 950 is probably worth 10 HP over the 750 you have.
Whatever it's going into better have at least a 5K stall converter and enough gear to keep the RPM up above 6K most of the time.
[Re: Wookie316]
#2069940
05/09/16 10:26 AM
05/09/16 10:26 AM
Posts: 326 Alberta
Wookie316
Alberta
8" 5400 stall. 4.30 gear. The Dyno it is going on is the same one my 511 went on. When I showed Dwayne the sheet from that I believe he thought it was about 20 HP higher than the #'s he'd see on his. So maybe it will go 640-650? I thought the 511 if it nosed over 700 it would just do it. It made 743. I like to guess low then I'm not bumbed out if it don't make that.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2070164
05/09/16 04:18 PM
05/09/16 04:18 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
I'm going to guess 550 to 575 HP with a little less torque.
[Re: CSK]
#2070284
05/09/16 08:22 PM
05/09/16 08:22 PM
Posts: 7,506 Az
Crizila
Az
Revising mine from 650 to 652!
Fastest 300
[Re: Wookie316]
#2070315
05/09/16 09:20 PM
05/09/16 09:20 PM
Posts: 326 Alberta
Wookie316
Alberta
My 511 when it had 11.3-1 CR and a little smaller cam than the one in my 440 made 655 HP @ 5900 with a 1 7/8x3 header. The heads off that 511 are now on this 440. This engine will be Dyno'd on same dyno. I have my buddy's 950 QTP, so it could go 650 + with that 950 and a 1" spacer and a 2x3.5 header?
[Re: Wookie316]
#2072474
05/13/16 09:32 AM
05/13/16 09:32 AM
Posts: 326 Alberta
Wookie316
Alberta
On my way to have engine Dyno'd. Should have #'s by this afternoon. Stay tuned.
[Re: Wookie316]
#2072520
05/13/16 11:12 AM
05/13/16 11:12 AM
Posts: 368 michigan
turbo toad
michigan
Good luck and keep us updated.
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: Wookie316]
#2072532
05/13/16 11:38 AM
05/13/16 11:38 AM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
What the heck. Here goes 611hp. Our dragster motor is not far off from what you have. Pump gas -1 with minimal work done. Small roller makes 650ish
[Re: Eric]
#2072663
05/13/16 03:40 PM
05/13/16 03:40 PM
Thumperdart
State of confusion
I have a Ray Murray 850cfm carb for sale if you are interested in getting that motor breathing Would hardly call an 850 "breathing" just saying............ I run those on most small blocks and dommys on big blocks myself............Sorry, 650 hp similar tq............
[Re: Wookie316]
#2072714
05/13/16 04:44 PM
05/13/16 04:44 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
850 is quite a bit bigger than a 750...actually bigger than a 950 correct?
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#2072761
05/13/16 05:30 PM
05/13/16 05:30 PM
Thumperdart
State of confusion
850 is quite a bit bigger than a 750...actually bigger than a 950 correct? Bigger than a 750 and SOME so called 950`s yes but no match for a good running BB imo.............
