Anybody running a complete RMS setup in a B Body on the track?
Where do you like to set your double abjustables?
Compression high, rebound low on the front? What about the back?
I have the lower bar set in the drag position but not sure where to start with on the shocks?
Hope to make some passes Friday and looking for a starting point?
4000 lbs beast with 4.30's and 740 HP.
Thanks guys.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
