Mopar M1 question #2070955
05/10/16 07:21 PM
05/10/16 07:21 PM
Vermont
bracketcharger Offline OP
Vermont
Can someone tell me what is the difference between these two manifolds; #4529463 and #4532174 ? Try not to beat me up too bad. Thanks Paul.
Re: Mopar M1 question [Re: bracketcharger] #2071065
05/10/16 09:56 PM
05/10/16 09:56 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
My books show the 1st part number as being a single plane and the 2nd as a dual plane. Both being for a RB.
Ok
Re: Mopar M1 question [Re: bracketcharger] #2071070
05/10/16 10:01 PM
05/10/16 10:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 463 is listed as a single 4bbl RB for stage 4 and 5
heads.. I dont show the other manifold in my books.. might
newer than my books
wave
Re: Mopar M1 question [Re: MR_P_BODY] #2071129
05/10/16 11:24 PM
05/10/16 11:24 PM
Vermont
Vermont
The 174 number is a casting number, would that be the same as a part number. I've found pictures of the 174 manifold and the number is cast in. I couldn't find any pictures of the 463 to see what #s are cast into it. From what I've found both are single plane for standard port heads RB block.
Re: Mopar M1 question [Re: bracketcharger] #2071133
05/10/16 11:29 PM
05/10/16 11:29 PM
Vermont
Vermont
I've heard good things about the 463. I have an opportunity the buy a 174 and I'm trying to determine if the two are essentially the same.
Re: Mopar M1 question [Re: bracketcharger] #2071144
05/10/16 11:42 PM
05/10/16 11:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know for fact but I'm damn sure that the 463
is the 4150 version of the P4529725 (4500 version)... the
casting numbers dont match the P/N of the part.. never
understood that
wave
Re: Mopar M1 question [Re: MR_P_BODY] #2071150
05/10/16 11:50 PM
05/10/16 11:50 PM
Vermont
Vermont
Could the 463 be the part number and 174 be the casting number ?
Re: Mopar M1 question [Re: bracketcharger] #2071206
05/11/16 12:43 AM
05/11/16 12:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure... it could be
EDIT
one of the post above says the 174 is a dual plane
wave
Re: Mopar M1 question [Re: MR_P_BODY] #2071220
05/11/16 12:55 AM
05/11/16 12:55 AM
Vermont
Vermont
I have a picture of the 174 and it's a single plane.
Re: Mopar M1 question [Re: bracketcharger] #2071393
05/11/16 12:18 PM
05/11/16 12:18 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Typically, the number cast on part is just that. Once machined, it gets another p/n pending its configuration. Meaning, different p/n standard port vs MW as an example.
The Monicatti Chrysler site has a chart. It's a stndrd port RB sngl plane.
Re: Mopar M1 question [Re: Dean_Kuzluzski] #2071580
05/11/16 06:15 PM
05/11/16 06:15 PM
Vermont
Vermont
Thanks everyone for the information.
Re: Mopar M1 question [Re: bracketcharger] #2072808
05/13/16 06:44 PM
05/13/16 06:44 PM
Vermont
Vermont
The big brown truck dropped off my intake today. It's an 4532174 looks like a twin to the 4529463 either way it's going to work much better than the old torker I was running.
