Dakota Wheel Fitment #2069279
05/08/16 12:25 PM
05/08/16 12:25 PM
Canada
Lugnutz Offline OP
Lugnutz  Offline OP
Canada
Will wheels/rims off a 2001 Dakota fit a 2004? All Dakotas 6 bolt I believe but if not these ones are. Would brake clearance on the 04 be an issue?
Thanks....
Re: Dakota Wheel Fitment [Re: Lugnutz] #2069327
05/08/16 01:29 PM
05/08/16 01:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Until 2005 body change, 6 bolts all since 91 and if you're choosing 16 inchers, they should fit fine. Even the 15's from 2001 may clear the biggest dakota brakes I THINK. Not sure about the rear disc trucks.
Re: Dakota Wheel Fitment [Re: Lugnutz] #2071353
05/11/16 11:09 AM
05/11/16 11:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what wheel are you trying to fit? some will, some won't
in 03, the dakotas and durangos got 12" rotors up front and 12" rotors on the back to replace the previous 11" rotors and drum brakes.
Because of this change, 15" wheels would no longer fit, and those years trucks had 16 or 17" wheels only.
**Photobucket sucks**
