Small Block Mopar Cam washer to eliminate eccentric #2066473
05/03/16 01:03 PM
05/03/16 01:03 PM
Pennsylvania
P
P7 Engineering Offline OP
P
Pennsylvania
I was talking to my brother Ryan at Shady Dell, and he said Chrysler no longer sells the small block cam washer that is used to eliminate the fuel pump eccentric. I drew the piece up in solidworks and had the piece quoted as a small CNC run. I wanted to see if there was any interest here for this part?
My 1974 2WD shortbed Chevy Truck build thread:
http://67-72chevytrucks.com/vboard/showthread.php?t=525098
Re: Small Block Mopar Cam washer to eliminate eccentric [Re: P7 Engineering] #2066497
05/03/16 01:52 PM
05/03/16 01:52 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Nice drawing, I think those can be purchased from hughesengines.com.
Re: Small Block Mopar Cam washer to eliminate eccentric [Re: P7 Engineering] #2066556
05/03/16 03:24 PM
05/03/16 03:24 PM
Washington
madscientist Offline
Washington
Yup. I used that (or part of it) to use my gear drive and keep the fuel pump eccentric.
Re: Small Block Mopar Cam washer to eliminate eccentric [Re: P7 Engineering] #2066605
05/03/16 05:16 PM
05/03/16 05:16 PM
Pennsylvania
P
P
Pennsylvania
I checked the Hughes website. They do offer one, just not the Mopar part number P4529838 that we used to get from them.
Re: Small Block Mopar Cam washer to eliminate eccentric [Re: P7 Engineering] #2066670
05/03/16 07:43 PM
05/03/16 07:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just make my own.. I leave .015 for cam end play..
pretty simple.. drill the hole and file the key slot
wave
Re: Small Block Mopar Cam washer to eliminate eccentric [Re: P7 Engineering] #2066866
05/04/16 12:07 AM
05/04/16 12:07 AM
Pennsylvania
P
P
Pennsylvania
..yes, likewise I might just turn a few on the lathe for what Ryan needs right now.
Re: Small Block Mopar Cam washer to eliminate eccentric [Re: P7 Engineering] #2068846
05/07/16 02:15 PM
05/07/16 02:15 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I'd be interested in a couple of them if you start building them. -Andy
