Page 2 of 5 1 2 3 4 5
Re: Let's hear some W7,W8,and W9 builds [Re: 340_Dart] #743297
12/29/11 06:55 PM
12/29/11 06:55 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
mine's a 440sb, 4"x 4.185 diamond pistons 11-1, w9's by ryan, 730 roller by bullet cams, callies crank, compustar rods, m1 intake, prosystems 1050 domy. best so far- 9.61@137.91 with some trans slippage. street ride. seeya.
Re: Let's hear some W7,W8,and W9 builds [Re: rickraw] #743298
12/29/11 07:23 PM
12/29/11 07:23 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My newest build will be an an indy headed project but I'll keep this one. Some nice builds thanks for sharing them.
Re: Let's hear some W7,W8,and W9 builds [Re: DavidDean] #743299
12/29/11 08:17 PM
12/29/11 08:17 PM
Long Island, New York
W
W7 Duster Offline
W7 Duster  Offline
W
417cid,R3 3.79X4.185
Chapman W7
Sheetmetal intake W/ 2 1050 AED Dominators
Best ET: 9.27 @ 143.75 @ 3000lbs.
Re: Let's hear some W7,W8,and W9 builds [Re: W7 Duster] #743300
12/29/11 08:36 PM
12/29/11 08:36 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
seeing this thread makes me want to throw out my w2 340 and start over....
Re: Let's hear some W7,W8,and W9 builds [Re: Uncle Barry] #743301
12/29/11 10:27 PM
12/29/11 10:27 PM
Ambridge, Pa.
Ambridge, Pa.
why??
Re: Let's hear some W7,W8,and W9 builds [Re: rickraw] #743302
12/29/11 10:44 PM
12/29/11 10:44 PM
U
Uncle Barry Offline
Uncle Barry  Offline
U
because this stuff would REALLY look good in my car
Re: Let's hear some W7,W8,and W9 builds [Re: Uncle Barry] #743303
12/29/11 11:00 PM
12/29/11 11:00 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Sold the CFE W8's but....
421 SB R3 358 WC block
Crower Ultralite crank 3.8" stroke
GRP rods
Diamond pistons
Bullet roller cam
Single four barrel cast intake
Best ET it ran 5.69
Best honest MPH 125 had a no name track that showed 128 but, I called BS.
The block has been tested due to an undetermined leak and no trouble was found in the questionable cylinder. The heads are sold sense then the block and intakes are in the for sale section. Could be somebodies lucky day.
Leon
Re: Let's hear some W7,W8,and W9 builds [Re: Uncle Barry] #743304
12/29/11 11:19 PM
12/29/11 11:19 PM
australia
charger410 Offline
charger410  Offline
australia
Ex sprintcar engine from Us in my Chug.
410in 4.15 x 3.8 A8 block
solid roller 268/50 780lift
W9 heads, titanium valves, pac springs, jessel rockers
JE pistons
Carrilo rods
Bryant Crankshaft
Barns 4 stage dry sump
Injecter stacks
1 7/8 step into 2inch pipes
Dyno 875hp 652fbs
Been running for 4years never touched the engine besides plugs and oil
Have only done street events on slippery tracks but will take it to the local 1/4mile track and see how it goes in a week and will post my time here good or bad
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Let's hear some W7,W8,and W9 builds [Re: charger410] #743305
12/30/11 11:12 AM
12/30/11 11:12 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
9" R3
3.79 Callies
4.185 bore
MGP rods
13.8 static
55mm cam
15* Coleman/Arrington W8
420 intake
SV-1
3 step header w/Burns merge
External wet sump
894hp-657tq
Built to spray a little, but decided to go N/A. Car is now finished just in time for the bad weather. We will run this engine for one season before selling it and doing a full N/A build.
Re: Let's hear some W7,W8,and W9 builds [Re: jim sciortino] #743306
12/30/11 11:38 AM
12/30/11 11:38 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Jim,
What is you rod length / compression height?
Bill
Re: Let's hear some W7,W8,and W9 builds [Re: 340Cuda] #743307
12/30/11 02:40 PM
12/30/11 02:40 PM
Trumbull,CT.
Trumbull,CT.
Jim,
Bill
5.990/1.130.....IIRC.
Diamond w/lateral gas ports.
Re: Let's hear some W7,W8,and W9 builds [Re: charger410] #743308
12/30/11 04:45 PM
12/30/11 04:45 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
very impressive boys! and jim you can put your motor on the ferry i'll pick it up on the other side somewhere in suffolk county
Re: Let's hear some W7,W8,and W9 builds [Re: fishy340] #743309
12/30/11 07:47 PM
12/30/11 07:47 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Hey Jim, who makes the 55 mm cam core?
Leon
Re: Let's hear some W7,W8,and W9 builds [Re: fishy340] #743310
12/31/11 09:52 AM
12/31/11 09:52 AM
Trumbull,CT.
Trumbull,CT.
Go to an ATCO rent day and take it right out of the car.
Re: Let's hear some W7,W8,and W9 builds [Re: Leon441] #743311
12/31/11 09:55 AM
12/31/11 09:55 AM
Trumbull,CT.
Trumbull,CT.
Leon
Dean just gave me a slap. It's a 50mm.
I should really re-read before I post.
Re: Let's hear some W7,W8,and W9 builds [Re: jim sciortino] #743312
12/31/11 04:13 PM
12/31/11 04:13 PM
Out West
408strokerdart Offline
Out West
9" R3
3.79 Callies
4.185 bore
MGP rods
13.8 static
55mm cam
420 intake
SV-1
External wet sump
894hp-657tq
Almost a clone to mine....why is mine such a turd by comparison? Hey Jim, could you share some cam/valvetrain specs on your build? PM if you want. No offense to any others, but this an impressive build for the power output. I am sure I am 100 hp less with almost the same combo and more compression.
Re: Let's hear some W7,W8,and W9 builds [Re: 408strokerdart] #743313
12/31/11 07:37 PM
12/31/11 07:37 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
9" R3
3.79 Callies
4.185 bore
MGP rods
13.8 static
55mm cam
420 intake
SV-1
External wet sump
894hp-657tq
Brian, I was thinking the same thing. Mine is very similar as well. I'm sure my combo is giving up some hp with the nitrous camshaft but 100 hp?
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Let's hear some W7,W8,and W9 builds [Re: Plumb Wired] #743314
12/31/11 09:07 PM
12/31/11 09:07 PM
Out West
Out West
9" R3
3.79 Callies
4.185 bore
MGP rods
13.8 static
55mm cam
420 intake
SV-1
External wet sump
894hp-657tq
Mike Gray
Yes Mike....ours are very similar as well. What is Jim doing so right that we are doing so wrong for the difference in hp? I can understand mine being slightly quicker than yours in (N/A) because I don't have a nitrous cam, but ours are pretty equally paired. I know Jim has beaten on his on the dyno for a long time and is wringing it out pretty good.
Re: Let's hear some W7,W8,and W9 builds [Re: fishy340] #743315
01/01/12 03:04 AM
01/01/12 03:04 AM
long island new york
K
kingdust Offline
kingdust  Offline
K
why, you can't drive what you have! happy new year.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: Let's hear some W7,W8,and W9 builds [Re: 408strokerdart] #743316
01/01/12 06:59 AM
01/01/12 06:59 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
9" R3
3.79 Callies
4.185 bore
MGP rods
13.8 static
55mm cam
420 intake
SV-1
External wet sump
894hp-657tq
I would say cylinder head/manifold/carb. Mine picked up 100hp with a head change and another 30 after the dyno with more carb work.
4.100 x 4.00 stroke Chapman w9 with 772 intake opened for a dominator. 754hp/615ftlbs. In my 3520lb barracuda has run a best of 9.66 at 138.6mph.
