1965 383 Lifters - unique to 67 & down?
#2067413
05/04/16 09:12 PM
05/04/16 09:12 PM
Posts: 1,012 Central US
grancuda
Central US
In buying a camshaft I have came across on Comp Cams site that the '67 & down use a different lifter. Other brands don't mention anything about the lifter difference. Anyone know the story with that? I have read it's possibly something with the tip of the pushrod. I am running stock pushrods.
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: 1965 383 Lifters - unique to 67 & down?
[Re: grancuda]
#2067418
05/04/16 09:16 PM
05/04/16 09:16 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you're going to run the original 1965 pushrods, you'll see that the lifter end is tapered down and fits snugly into the pushrod seat of the lifter. That style of pushrod should be paired with the. 67 and earlier lifters. If you want to use the more common 68 and later style, you'll want to replace the pushrods with 1968 and later versions.
[Re: grancuda]
#2067419
05/04/16 09:18 PM
05/04/16 09:18 PM
grancuda
Central US
Are the 65 pushrods weaker? They are in good condition.
[Re: grancuda]
#2067420
05/04/16 09:23 PM
05/04/16 09:23 PM
fast68plymouth
So. Burlington, Vt.
Not that I'm aware of, you just need to use the correct lifters.
Do your pushrods have one end that is noticeably smaller than the other end?
[Re: grancuda]
#2067429
05/04/16 09:29 PM
05/04/16 09:29 PM
fast68plymouth
So. Burlington, Vt.
Then you should be good if you use the early style lifters.
[Re: Chuck@Best_Machine]
#2067432
05/04/16 09:35 PM
05/04/16 09:35 PM
fast68plymouth
So. Burlington, Vt.
I believe the early pushrods were a different length also The early pushrods are shown as .060 longer. I think the early lifters have the pushrods sitting deeper in the cup, so they needed to be longer.
[Re: grancuda]
#2067500
05/04/16 11:04 PM
05/04/16 11:04 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Correct as the early rods are longer.You cant use them with new lifters.All cam makers listed 68 up lifters before dont know if they still do.Summit has nice push rods for stock valve setups with new style lifters.Used them when we did the 62 413 and the 67 Chrysler and the other early BBs I did.Rocky
Chrysler Firepower
[Re: 67_Satellite]
#2067730
05/05/16 01:34 PM
05/05/16 01:34 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
Smaller radius on the pushrod end "ball" pre 67 1967 and older. 1968 first year with both ends the same.
[Re: @#$%&*!]
#2067791
05/05/16 03:28 PM
05/05/16 03:28 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm pretty sure Chrysler went from 5/16" pushrod ends to 3/8" in 1968. Nope, '68 and later are 5/16" both ends, the '67 and earlier are 5/16" top and 1/4" bottom.
[Re: JohnRR]
#2068835
05/07/16 01:54 PM
05/07/16 01:54 PM
fast68plymouth
So. Burlington, Vt.
Are the early lifters even still available ?
Comp - 824-16 Eaton/SBI - VL8 Johnson - A-812 Federal Mogul - HT1812
