Where to get this door weatherstrip/cat whiskers/belt strip? #2066715
05/03/16 09:04 PM
05/03/16 09:04 PM
Virginia
JimG Offline OP
JimG  Offline OP
Virginia
I'm restoring a '71 Satellite 4-door and need this cat whiskers/outer belt strip (wipes the window when it rolls up or down) for all four doors.
I checked Restoration Specialties catalog, and they have similar, but not exact, material that is listed for other makes.
If someone sells 2-door material is identical, but in longer lengths, I suppose I could buy two kits and cut them to length.
Any suggestions? Thanks in advance.
Re: Where to get this door weatherstrip/cat whiskers/belt strip? [Re: JimG] #2066933
05/04/16 01:52 AM
05/04/16 01:52 AM
Any suggestions?
www.classicindustries.com may have something. I'd check out their inventory online & if you make a small purchase from them then in a week their pricey mopar specific catalogue will arrive in your mailbox for free & it is a worthwhile addition to your collection as it has a ton of reference pics. If they have the strip you are seeking be sure to JB weld it so it will stay in place
Re: Where to get this door weatherstrip/cat whiskers/belt strip? [Re: RapidRobert] #2066967
05/04/16 03:28 AM
05/04/16 03:28 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
First Place Auto Products used to make the best. Fritz, the owner died some time ago, and someone is carrying on the good name. I would check into them for sure. FPAP.com
I’m listening.
Re: Where to get this door weatherstrip/cat whiskers/belt strip? [Re: JimG] #2066998
05/04/16 08:59 AM
05/04/16 08:59 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
call Dixie Restoration. Randy may be able to get them cut to length. He's offered to do custom stuff work before as he works closely with Restoration Specialties.
Re: Where to get this door weatherstrip/cat whiskers/belt strip? [Re: RapidRobert] #2067019
05/04/16 10:02 AM
05/04/16 10:02 AM
Virginia
JimG Offline OP
JimG  Offline OP
Virginia
Originally Posted By RapidRobert
Any suggestions?
Boy, some things never drop down the memory hole!
Re: Where to get this door weatherstrip/cat whiskers/belt strip? [Re: JimG] #2067274
05/04/16 05:17 PM
05/04/16 05:17 PM
it lets me know that alheimers ain't set in yet
