407 head gasket question #2067160
05/04/16 02:24 PM
05/04/16 02:24 PM
Loveland CO
Jimbo Offline OP
Jimbo  Offline OP
Loveland CO
I just got my comtec gaskets for my 470 build, the hole diameter is stated to be 4.380. my bore is 4.370, and the gaskets are very clos to the edge of the bore, and actually hang over the edge at the top of the bore because of the slight taper at the top of the cylinder. has anyone run across this, or do I need to find other gaskets
Re: 407 head gasket question [Re: Jimbo] #2067170
05/04/16 02:36 PM
05/04/16 02:36 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Find other gaskets. Cometic told me .015 to .030 back from the bore. He also said if it hangs in the bore it will fail.
2011 Drag Pak Challenger
Re: 407 head gasket question [Re: rickseeman] #2067309
05/04/16 06:24 PM
05/04/16 06:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... get larger bore gaskets... they will burn out
wave
Re: 407 head gasket question [Re: Jimbo] #2067529
05/04/16 11:38 PM
05/04/16 11:38 PM
AndyF Offline
AndyF  Offline
C5462 is probably what you want. That is the gasket that I use on my 470. The bore size is 4.410 so you have 0.020 of clearance around the edge. If the bevel on the top of the bore is really big then you need to go to an even larger gasket. If the block isn't machined yet then you can cut the deck and knock the bevel down a bit.
