And now on to Valve Springs...
#2066884
05/04/16 12:41 AM
05/04/16 12:41 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Looking to run the Hughes Whiplash cam, in the 383.
Hughes recommends their valve springs:
Installed Height/Pressure: 1.880"--150# Pressure @ .450" lift: 315# Pressure @ .500" lift: 325# Pressure @ .550" lift: 335# Pressure @ .600" lift: 350# Pressure @ .650" lift: 365# Coil Bind: .680" lift Outer Spring ID/OD: 1.130"/1.540" Type of Spring: Single w/ damper
I know almost nothing about valve springs, how do these compare to stock? Is there another brand spring you guys might recommend that wont have the Hughes price tag?
I'm building on a budget, so if I can find a comparable spring for less than the $92 I would like to see what is available. I dont know if $92 is a decent price or not.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: And now on to Valve Springs...
[Re: hp383]
#2066892
05/04/16 12:49 AM
05/04/16 12:49 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Stock 440 HP springs; Open 258 lbs. @ 1.40" (around .450" lift) Closed 129 lbs. @ 1.86"
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: hp383]
#2066904
05/04/16 01:02 AM
05/04/16 01:02 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
Ron dont know the specs but I run Comps in my 440.I would have to look at the box to see what set they are.Comp solid cam is .588 320 duration.Been in for about 16 years and no problems.We ran my old Isky springs in the 413 when Jesse ran the Huges cam.They were like 35 years old and worked better than new.Rocky
Chrysler Firepower
[Re: hp383]
#2066905
05/04/16 01:03 AM
05/04/16 01:03 AM
therocks
Niles , Ohio
Dont know the specs on that cam but I run Comps in my 440.I would have to look at the box to see what set they are.Comp solid cam is .588 320 duration.Been in for about 16 years and no problems.We ran my old Isky springs in the 413 when Jesse ran the Huges cam.They were like 35 years old and worked better than new.Rocky
Chrysler Firepower
[Re: hp383]
#2066907
05/04/16 01:04 AM
05/04/16 01:04 AM
hp383
State of Confusion
OK, Would you happen to have a part number, or other brand equivalent?
Im really at a loss trying to spec them out, and Summit no longer offers a by engine search on valve springs, (and piston rings by the way) you need to supply all the diameters inner, outer, height, coil bind, pressure, etc. And its kinda all Greek to me.
Thanks for the assistance.
[Re: hp383]
#2066911
05/04/16 01:13 AM
05/04/16 01:13 AM
hp383
State of Confusion
Here are the specs on the cam.
[Re: hp383]
#2066912
05/04/16 01:14 AM
05/04/16 01:14 AM
hp383
State of Confusion
I will be running the stock 1.5 rocker, unless there is a deal on a 1.6 ration rocker out there.
[Re: hp383]
#2066922
05/04/16 01:37 AM
05/04/16 01:37 AM
Posts: 4,457 Washington
madscientist
Washington
I like it way better with a 1.6 rocker.
The springs are on the high side of pressure. Better have your poop wired tight when firing the engine.
You are within less than 1% of what I'm using.
[Re: hp383]
#2066945
05/04/16 02:19 AM
05/04/16 02:19 AM
hp383
State of Confusion
Have you seen what they charge for the 1.6 rockers? I dont think I want to trust a china made set, and the next level are over $700 for the Crane.
And just to take this way off topic, I was thinking of running a 1/2 grooved rod bearing, because I do plan to spray the motor, but with steel rods, and bearings with dowel pin holes, do I need to pin the rods, or can the hole just ride as is?
[Re: hp383]
#2067155
05/04/16 02:22 PM
05/04/16 02:22 PM
hp383
State of Confusion
I already have a set of hardened pushrods.
And are the Mopar Performance stamped rockers any different that the OEM?
They were on my previous 383 that had the 292/509 cam, and stiffer springs, they dont show any funky wear.
[Re: hp383]
#2067218
05/04/16 03:34 PM
05/04/16 03:34 PM
madscientist
Washington
Just order some PRW stainless steel 1.6 rockers and be done with it. You can also find good used rockers for sale all the time.
You want to build a nice piece and use a junk rocker. What gives? Don't step over donuts to pick up dog turds.
[Re: hp383]
#2072849
05/13/16 08:02 PM
05/13/16 08:02 PM
hp383
State of Confusion
Thanks for the tip on the PRW rockers. I just scored a set new for $375.
I never said I wanted to use a junk rocker. Just wasn't having luck finding a good one I could afford.
