Changing axle studs?
#2065562
05/01/16 10:51 PM
05/01/16 10:51 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
What method do you prefer to knock out the old studs then install them with the axles still in the car? The local service station has a bearing looking stud installation tool I can use. I have only ever just pulled them in with a lug nut, and knocked them out with a hammer, but that was just daily driver cars and I would like these to be installed more correctly. Thanks! Greg
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
Re: Changing axle studs?
[Re: G-Money1320]
#2065619
05/02/16 12:02 AM
05/02/16 12:02 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I do them all the time with the stud installer and they seat just fine every time. I just put a little red Lock-tite on the splines for lube and extra insurance after it when they are seated. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: G-Money1320]
#2065705
05/02/16 02:56 AM
05/02/16 02:56 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
What method do you prefer to knock out the old studs then install them with the axles still in the car? The local service station has a bearing looking stud installation tool I can use. I have only ever just pulled them in with a lug nut, and knocked them out with a hammer, but that was just daily driver cars and I would like these to be installed more correctly. Thanks! Greg I have used the BFH and lug nut method with the DD, too. I used it on the first racer I built 30+ years ago, but recently I inherited a bearing press and I am building the accessories needed to press wheel bearings on & off and install standard and long wheel studs. So now I won't have to be concerned about damaging axle flanges.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: G-Money1320]
#2065952
05/02/16 03:04 PM
05/02/16 03:04 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
BG sounds like you do them like I have at the shop.Probally installed hundreds that way if not thousands.Rocky
Chrysler Firepower
[Re: B G Racing]
#2067496
05/04/16 10:59 PM
05/04/16 10:59 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
Thanks, for your tips #1 BFH to knock them out and #2 I will borrow the install tool. Hope to see some of you out this year!!
