Page 7 of 16 1 2 5 6 7 8 9 15 16
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2083872
06/01/16 03:31 AM
06/01/16 03:31 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hopefully that translates to a good hookin/handlin car.......
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2083875
06/01/16 03:41 AM
06/01/16 03:41 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Well done mate, it's looking great.
1963 Plymouth Max Wedge
1971 Barracuda
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2084380
06/01/16 11:46 PM
06/01/16 11:46 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Thanks, guys. I hope it hooks as good as it looks, too. I'd like it to run like a 160 mph Cadillac.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2087442
06/06/16 11:39 PM
06/06/16 11:39 PM
sgcuda Offline OP
sgcuda  Offline OP
Got the brackets for the trans crossmember welded in this weekend, although I might swap out the dropped crossmember for a straight bar, since the engine and trans are sitting higher than expected. Ladder bar diagonal link is finished, also. Got the majority of the X brace between the trans crossmember and the ladder bar done. One more section left. I also figured out my welding problems. Evidently, the AllStar tubing I have been buying through Summit is not only coated on the outside with oil, but I found out the tubes are coated on the inside. The oil on the inside has been boiling and steaming out through the gaps, giving me fits. A little brake clean and some air went a long way to fixing that problem.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2087593
06/07/16 08:54 AM
06/07/16 08:54 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Kenny, DO NOT use brake clean before welding anymore! When heated it will create phosgene gas and it can kill you! You need to stick around to enjoy the fruits of your labor.
Re: OK! No more BS. Time to start working. [Re: 496 A-body] #2087601
06/07/16 09:56 AM
06/07/16 09:56 AM
moparx Offline
moparx  Offline
POSITIVELY CAN'T BE EMPHASIZED ENOUGH !!!! eek please guys, DO NOT EVER use brake kleen to clean joints before welding !!!
beer
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2088001
06/07/16 10:22 PM
06/07/16 10:22 PM
sgcuda Offline OP
sgcuda  Offline OP
OK. I'll make sure I don't forget this one. I'm so glad they changed the chemical composition of brake clean to help out the birds and the frogs. FYI, with the heat and humidity here, I wasn't doing any welding without everything being bone dry. How about cleaning out the tubing with rubbing alcohol?
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2088010
06/07/16 10:32 PM
06/07/16 10:32 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What to use them?
Mopar to the bone!!!
Re: OK! No more BS. Time to start working. [Re: 72Swinger] #2088013
06/07/16 10:35 PM
06/07/16 10:35 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted By 72Swinger
What to use them?
Acetone
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2088023
06/07/16 10:49 PM
06/07/16 10:49 PM
sgcuda Offline OP
sgcuda  Offline OP
I can use acetone even if I don't have nail polish on that day?
All kidding aside, I appreciate the valuable input from you guys, once again. The outside is easy enough to clean with soap and water, but the inside of the tubing is coated in oil as well.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2094162
06/18/16 10:41 PM
06/18/16 10:41 PM
sgcuda Offline OP
sgcuda  Offline OP
Well, X brace is in, but I mounted it flush to the top of the frame rails, and I think I am going to have an interference issue with the driveshaft. I meant to mount it low, but forgot. Will probably end up cutting it out and putting a new X brace in lower in the frame. Added doubler tabs on the trans member mounts. Changed to a straight tube for the trans and still have to add a mounting pad. Painted the ladder bars and axle housing. Cut the front cross braces out from the frame to the rocker bars, so that I can fit in bent tubes to clear the headers. Man, that C/M tubing is tough stuff. Went through 3 Dewalt SawZall blades before I broke out the grinder with a cutoff wheel. Right side header fits better than I could ever build. Left side fits like crap. Touching the frame rail, seriously pointed down. Not sure yet if I am going to modify it or just build my own left side header.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2094292
06/19/16 03:33 AM
06/19/16 03:33 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin great man....... beer punkrocka
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2103302
07/03/16 11:05 PM
07/03/16 11:05 PM
sgcuda Offline OP
sgcuda  Offline OP
Haven't made too much progress. Head not on straight lately, bunch of crap at work. Got the pinion gear installed. Brought home wrong tool kit for spool bearing shims. Put Strange cover on to see how it looks. Got rear suspension painted up and put back in frame. Now to figure out all of the driveshaft angles.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2103338
07/04/16 12:04 AM
07/04/16 12:04 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks great man and can`t wait to see the end result............ beer
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2103388
07/04/16 01:29 AM
07/04/16 01:29 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Lookin good!
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2103495
07/04/16 11:42 AM
07/04/16 11:42 AM
sgcuda Offline OP
sgcuda  Offline OP
Thinking about a set of side exit headers. Probably exit through the lower fender in back of the front wheel. Does anyone have any experience with them? Do the exhaust rings really work as far as keeping the fiberglass from burning? Do those collector exhaust cones help keep the noise down without sacrificing too much power?
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2103588
07/04/16 01:52 PM
07/04/16 01:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run my exhaust through the fiberglass hood. I use a ring I made out of aluminum. No issues
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2103812
07/04/16 07:11 PM
07/04/16 07:11 PM
sgcuda Offline OP
sgcuda  Offline OP
Trying to get back on track. Set the tranny height to get my driveshaft angle close. Adjusted the ladder bars to get the pinion angle in line, too. Mounted the body back on, ran some jigs to keep the steering column and pedals in line. Then I unbolted the assembly from the firewall and weighed it. Another 35 pounds. Will probably mount a race steering column kit and pedals to the cage. I like the idea of the reverse mounted master cylinder, too. Just make an access panel on top of the new dash for fluid fill.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2132763
08/14/16 05:16 PM
08/14/16 05:16 PM
sgcuda Offline OP
sgcuda  Offline OP
Not much to report lately. Slowly, getting back on track. Finally got the nose at least dropped onto the new frame. Need to come up with some ideas to make it quick take off and reinstall.
Heat and humidity is killer today. Internet says 94 degrees, feels like 105. To me, it feels at least 100 degrees hotter.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2132790
08/14/16 05:58 PM
08/14/16 05:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs thumbs beer boogie penguin drinking
