A Body Barracuda Spare Tire/Rim Size
#2061991
04/26/16 01:33 PM
04/26/16 01:33 PM
Posts: 3,287 Stroudsburg, PA
Erik
Stroudsburg, PA
What is the correct size rim and spare tire for an A body Barracuda? Need to get the right size for mine.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A Body Barracuda Spare Tire/Rim Size
[Re: Erik]
#2062018
04/26/16 02:41 PM
04/26/16 02:41 PM
Erik
Stroudsburg, PA
Thanks. When in the spare well, should the top of the tire be flush with the trunk floor or does it rise above the trunk floor? The spare I have now rises above the trunk floor so the board is above the rest of the floor. Is that correct?
[Re: 6bblgt]
#2063512
04/28/16 06:15 PM
04/28/16 06:15 PM
Posts: 4,127 Ramona, CA
NicksGarage
Ramona, CA
I think all of the 14x5.5" wheel/tire spares are above the trunk floor. the 13" & 14x4.5" available combos sit "more flush". Yes and it's ugly that way. If you want a clean look, use the narrower wheel.
[Re: Erik]
#2063807
04/29/16 03:14 AM
04/29/16 03:14 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
If the factory provided fiberboard spare hold-down cover is used, it will eventually crown or droop over the edges of the 5.5" wheel/tire. Personally I won't say this is ugly, but in time the fiberboard won't be flat anymore.
Photo shows a flat fiberboard cover under the mat on a 5.5" wheel that is higher elevation than the rest of the trunk.
[Re: RoadRunnerJD]
#2066976
05/04/16 03:55 AM
05/04/16 03:55 AM
kentj340
Cut and Shoot, TX
The original trunk mat had a mat of 1" or so of a horsehair type of padding glued to the underside of the trunk mat on either side of the spare tire cover to raise the mat so that it was pretty flat Interesting. My car with 5.5" wheels was not delivered with that padding.
