Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2065017
04/30/16 11:32 PM
04/30/16 11:32 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Mine is a 4spd 3:54 with a 215 blade as shown on the broadcast sheet, to help fill in the blank a bit.
1969 Hemi Roadrunner 2nd owner
Re: 69 hemi charger radiator fan: 215 or 216? [Re: domingo] #2065142
05/01/16 09:49 AM
05/01/16 09:49 AM
moparx Offline
moparx  Offline
Originally Posted By domingo
Im gonna check for straightness on the blades while turning it on a water pump i have bolted to a block..... and then I will also have it balanced just to be safe....dont trust an old fan that has been tossed around for years.
how will you balance it if needed ? static or dynamic balance ? add or remove weight and where ? i'm curious, as i have never seen this done. thanks in advance. please take pics.
beer
Dynamic. Usually balance is corrected by making sure the blades are even and centered and with the same pitch and then balance is corrected by adding weight via special balancing rivets on the blades.
please take some pics of your process when you do this, as i have never seen this done. thanks domingo !
beer
