Re: Cheapest way to get reliable starting
[Re: xyxxjx]
#2063861
04/29/16 10:11 AM
04/29/16 10:11 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
An AFB on a 73 anything is not stock, so who knows what you actually have for a choke setup, because a 73 4bbl intake isn't compatible with an AFB nor is it's choke setup.
Sounds to me like somone's been monkeying around under the hood.
[Re: DARTH V8Я]
#2063973
04/29/16 01:32 PM
04/29/16 01:32 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
Test the volts at the alternator with the engine running also. Just sayin. And bring the rpms above 1200 rpm , the original mopar alts don't put out full voltage at idle.
[Re: Supercuda]
#2064164
04/29/16 06:39 PM
04/29/16 06:39 PM
Posts: 206 Los Angeles CA
xyxxjx
Los Angeles CA
Sounds to me like somone's been monkeying around under the hood. Interesting information. Yes the previous owner put the afb on. i believe the intake was changed too. I know the mechanic who was working on the choke recently, I'll try and ask him.
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far.
Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be.
Don't protect a feminist when the collapse comes!
[Re: JohnRR]
#2064165
04/29/16 06:44 PM
04/29/16 06:44 PM
xyxxjx
Los Angeles CA
Test the volts at the alternator with the engine running also. Just sayin. And bring the rpms above 1200 rpm , the original mopar alts don't put out full voltage at idle. Where would I put the meter probes to measure directly off the alternator?
[Re: xyxxjx]
#2064168
04/29/16 06:52 PM
04/29/16 06:52 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
black to ground (alternator case) red to the battery out terminal ( thickest wire on the back of the alternator).
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: xyxxjx]
#2064504
04/30/16 03:08 AM
04/30/16 03:08 AM
xyxxjx
Los Angeles CA
Ok, problem solved, I think. I went and got the battery charged, now it fires right up without any hesitation. I think what happened was that I recently had a car alarm installed. I noticed the car had the doors and trunk open when I came to pick it up, it had probably been sitting like that for a couple of hours. So the dome light trunk liigh and buzzer must have drained the battery below where the alternator could top it off. How much power do the bulbs draw? Can you get low energy ones?
[Re: xyxxjx]
#2064646
04/30/16 12:46 PM
04/30/16 12:46 PM
JohnRR
Ok, problem solved, I think. I went and got the battery charged, now it fires right up without any hesitation. I think what happened was that I recently had a car alarm installed. I noticed the car had the doors and trunk open when I came to pick it up, it had probably been sitting like that for a couple of hours. So the dome light trunk liigh and buzzer must have drained the battery below where the alternator could top it off. How much power do the bulbs draw? Can you get low energy ones? So what you are saying is that this was a one time occurrence and the shop that did the install is about 500 ft from your house and that drive wasn't enough to top off the battery?
[Re: BigBlockMopar]
#2064647
04/30/16 12:48 PM
04/30/16 12:48 PM
JohnRR
It's funny to see how some folks seem to "step over" the easiest tests to do and actually try to find a problem.
Considering how vague the question was, and the issues that people have here in the states with piss poor gas quality especially in commiefornia, what do you expect.
[Re: JohnRR]
#2064909
04/30/16 08:13 PM
04/30/16 08:13 PM
xyxxjx
Los Angeles CA
I Ok, problem solved, I think. I went and got the battery charged, now it fires right up without any hesitation. I think what happened was that I recently had a car alarm installed. I noticed the car had the doors and trunk open when I came to pick it up, it had probably been sitting like that for a couple of hours. So the dome light trunk liigh and buzzer must have drained the battery below where the alternator could top it off. How much power do the bulbs draw? Can you get low energy ones? So what you are saying is that this was a one time occurrence and the shop that did the install is about 500 ft from your house and that drive wasn't enough to top off the battery? It was just a guess, I'm certainly no car expert as you can probably tell ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) the shop was 10 miles from my home. But I don't know for sure if the problem is gone. I'll keep an eye on it over the next few days and then look into some of the other things people have suggested. Most things are old on this car so it may very well be some other problem.
[Re: xyxxjx]
#2065035
05/01/16 12:01 AM
05/01/16 12:01 AM
DARTH V8Я
Its a TRAP!
I Ok, problem solved, I think. I went and got the battery charged, now it fires right up without any hesitation. I think what happened was that I recently had a car alarm installed. I noticed the car had the doors and trunk open when I came to pick it up, it had probably been sitting like that for a couple of hours. So the dome light trunk liigh and buzzer must have drained the battery below where the alternator could top it off. How much power do the bulbs draw? Can you get low energy ones? So what you are saying is that this was a one time occurrence and the shop that did the install is about 500 ft from your house and that drive wasn't enough to top off the battery? It was just a guess, I'm certainly no car expert as you can probably tell ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) the shop was 10 miles from my home. But I don't know for sure if the problem is gone. I'll keep an eye on it over the next few days and then look into some of the other things people have suggested. Most things are old on this car so it may very well be some other problem. You should have an amp gauge. it'll show D ALT C. Where's the needle when ur driving? Are the headlights brighter when driving? Did you even check the volts @ high idle (1000rpm) @ the alternator? http://www.todayifoundout.com/index.php/2010/01/how-to-test-a-car-alternator/
[Re: OzHemi]
#2065040
05/01/16 12:12 AM
05/01/16 12:12 AM
xyxxjx
Los Angeles CA
If your charging system isn't working correctly.. (which if the voltage was at 12, it is not) just watch you don't get stuck some where when the freshly charged battery slowly gets dragged down and end up with not enough power to start the car..
The old way to check was to start the car, and pull the battery terminal off and the car should keep running.. (I wouldn't do this with modern electronics of course but it was an old school simple way to check if you didn't have test equipment around) I already tried pulling the negative terminal off the battery with the car running and it kept running. How do alternators go bad? Do they just stop working or do they deteriorate to point where they can just keep the car running but charges very poorly? I wouldn't be opposed to just buying a new one, they don't seem that expensive.
[Re: DARTH V8Я]
#2065072
05/01/16 01:39 AM
05/01/16 01:39 AM
xyxxjx
Los Angeles CA
I Ok, problem solved, I think. I went and got the battery charged, now it fires right up without any hesitation. I think what happened was that I recently had a car alarm installed. I noticed the car had the doors and trunk open when I came to pick it up, it had probably been sitting like that for a couple of hours. So the dome light trunk liigh and buzzer must have drained the battery below where the alternator could top it off. How much power do the bulbs draw? Can you get low energy ones? So what you are saying is that this was a one time occurrence and the shop that did the install is about 500 ft from your house and that drive wasn't enough to top off the battery? It was just a guess, I'm certainly no car expert as you can probably tell ![laugh laugh](/ubbthreads/images/graemlins/custom/laugh.gif) the shop was 10 miles from my home. But I don't know for sure if the problem is gone. I'll keep an eye on it over the next few days and then look into some of the other things people have suggested. Most things are old on this car so it may very well be some other problem. You should have an amp gauge. it'll show D ALT C. Where's the needle when ur driving? Are the headlights brighter when driving? Did you even check the volts @ high idle (1000rpm) @ the alternator? http://www.todayifoundout.com/index.php/2010/01/how-to-test-a-car-alternator/ Measurement taken at alternator 14.2v-14.4v idle, 14.6v reved up to what i think was around 1200, don't have rpm gauge. Ameter is usually somewhere around slightly right of middle just touching the thick middle line. Often when i first start it's a bit to the right of that.
[Re: xyxxjx]
#2065078
05/01/16 01:56 AM
05/01/16 01:56 AM
DARTH V8Я
Its a TRAP!
Then ur good on the Alt/voltage regulator.
[Re: DARTH V8Я]
#2065086
05/01/16 02:11 AM
05/01/16 02:11 AM
xyxxjx
Los Angeles CA
Then ur good on the Alt/voltage regulator. So if I wanted better starting, would i look into getting better spark?
[Re: xyxxjx]
#2065089
05/01/16 02:12 AM
05/01/16 02:12 AM
DARTH V8Я
Its a TRAP!
Whats the base timing at?
[Re: DARTH V8Я]
#2065097
05/01/16 02:23 AM
05/01/16 02:23 AM
xyxxjx
Los Angeles CA
Whats the base timing at? Sorry i don't know. My automotive skills are beginner level, but I would like to learn.
