Re: How much clearancey between lifter link/rivets and block? [Re: 416challenger] #2063474
04/28/16 04:41 PM
04/28/16 04:41 PM
It amazes nme how bad my memory is sometimes, this picture revived my memorys of the SB L.A. 59 degree motors having the worst pushrod angle I know of made by Mopar other than them dang 426 Hemiroid motors whistling shruggy Thanks for the update and picture bowthumbs
Re: How much clearancey between lifter link/rivets and block? [Re: dragram440] #2063483
04/28/16 04:54 PM
04/28/16 04:54 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
You should look for the linkbar itself, as the slotted part is longer and can interfere with the front/rear of the block. If so, swithc it around and get the fixed part of the linkbar closest to the block. I tried this a couple times, and it is easy to make this mistake.... For a big block or Hemi.
Re: How much clearancey between lifter link/rivets and block? [Re: kielbasa] #2063491
04/28/16 05:22 PM
04/28/16 05:22 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
59* block, link bars next to the valley wall, like in the pic.
If it has a true .015 clearance, I'd run it .
If something wears to the point where that .015 goes away, you've got other problems.
Check every pair, it's often the case where some clear, some don't.
