Re: Victor RB intake plenum , leave as is or unshroud corners?
[Re: Blown 68 R/T]
#2060839
04/24/16 02:44 PM
04/24/16 02:44 PM
Posts: 326 Alberta
Wookie316
Alberta
IQ52 who is a member on another board, not sure if he is here or not? Anyway he claims any major wok on a Victor intake is actually going backwards. Claims Eddy did their homework on that intake. But I suppose that all depends on the combo?
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2060843
04/24/16 02:52 PM
04/24/16 02:52 PM
Thumperdart
State of confusion
Mine is HEAVILY ported/modified and easily put my junk in the high 9`s at 3200+ lbs and now at around 3050 I`m hoping to improve greatly over that. Not a pro porter but now you can look all of the way down my intake and see most of the roof line kinda like a NASCAR intake and shows no puddling or weird distribution............
[Re: Blown 68 R/T]
#2060884
04/24/16 04:25 PM
04/24/16 04:25 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I always looked at the eyebrows as a way to add length to the runner. If you are running a combo that can benefit from a shorter runner(higher rpm), then I think removing them would help, as it did on Brads 452.
For the most part, on the running engine, the air doesn't really go from the carb right down into the cylinder. There are pulses bouncing back and forth the whole length of the runner. Slight changes in length will change the point at which the manifold is most effective, which will be slightly different depending on the basic engine configuration.
[Re: fast68plymouth]
#2061028
04/24/16 09:21 PM
04/24/16 09:21 PM
Posts: 525 Shannonville, Ont
Blown 68 R/T
Shannonville, Ont
Thanks for the feedback guys..... Now here's another factor, i'm running a F2 Procharger and a 950 Prosystems blow thru carb on it so do I remove the eyebrows or just smooth them out???
[Re: LaRoy Engines]
#2061049
04/24/16 09:54 PM
04/24/16 09:54 PM
BradH
496 stroker, RPM heads, Victor Intake.
Average torque/horsepower, 3000-6100rpm, with the brows smoothed but not removed 560.4TQ/485.7HP
Average torque/horsepower, 3000-6100rpm, with the brows removed .............................556.9TQ/483.6HP Interesting... did you also test a stock one to see how all three versions compared?
[Re: Wookie316]
#2061051
04/24/16 09:57 PM
04/24/16 09:57 PM
BradH
IQ52 who is a member on another board, not sure if he is here or not? IQ52 and LaRoy Engines are either the same person, or father & son.
#2061055
04/24/16 10:05 PM
04/24/16 10:05 PM
BradH
If you are running a combo that can benefit from a shorter runner(higher rpm), then I think removing them would help, as it did on Brads 452. If others are interested, we ran those tests from 3500 - 7000, and the HP peak was usually at 6300 to 6400.
[Re: BradH]
#2061132
04/25/16 12:03 AM
04/25/16 12:03 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
If you are running a combo that can benefit from a shorter runner(higher rpm), then I think removing them would help, as it did on Brads 452. If others are interested, we ran those tests from 3500 - 7000, and the HP peak was usually at 6300 to 6400. And on a street/strip race car with a 4500 or plus vert. Id want to know the averages from that rpm and above. Not starting at 3000 or 3500 rpm for a more accurate data. Brads test is a better reference to that model.
[Re: BradH]
#2062878
04/27/16 06:39 PM
04/27/16 06:39 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Average torque/horsepower, 3000-6100rpm, with the brows removed .............................556.9TQ/483.6HP Interesting... did you also test a stock one to see how all three versions compared? Yeah I did, used the same manifold for all, well, five tests actually. RPM..........OOTB.........smooth brow.......remove brow 3000......519tq/297hp........522/298.........511/292 3200........548/334..........539/329.........525/320 3400........585/379..........591/383.........592/383 3600........605/415..........609/418.........604/414 3800........609/440..........611/442.........608/440 4000........607/462..........614/467.........610/464 4200........604/483..........615/491.........609/487 4400........599/502..........602/505.........604/506 4600........605/530..........606/531.........611/535 4800........606/554..........608/556.........613/560 5000........611/581..........617/588.........616/587 5200........608/602..........619/612.........608/602 5400........602/619..........606/623.........601/618 5600........592/632..........597/636.........594/634 5800........577/637..........584/644.........581/642 6000........555/634..........564/644.........566/646 6100........542/629..........562/653.........554/644 Didn't pull this engine any higher.
[Re: LaRoy Engines]
#2063010
04/27/16 10:09 PM
04/27/16 10:09 PM
Thumperdart
State of confusion
Average torque/horsepower, 3000-6100rpm, with the brows removed .............................556.9TQ/483.6HP Interesting... did you also test a stock one to see how all three versions compared? Yeah I did, used the same manifold for all, well, five tests actually. RPM..........OOTB.........smooth brow.......remove brow 3000......519tq/297hp........522/298.........511/292 3200........548/334..........539/329.........525/320 3400........585/379..........591/383.........592/383 3600........605/415..........609/418.........604/414 3800........609/440..........611/442.........608/440 4000........607/462..........614/467.........610/464 4200........604/483..........615/491.........609/487 4400........599/502..........602/505.........604/506 4600........605/530..........606/531.........611/535 4800........606/554..........608/556.........613/560 5000........611/581..........617/588.........616/587 5200........608/602..........619/612.........608/602 5400........602/619..........606/623.........601/618 5600........692/632..........597/636.........594/634 5800........577/637..........584/644.........581/642 6000........555/634..........564/644.........566/646 6100........542/629..........562/653.........554/644 Didn't pull this engine any higher. I assume a misprint on line one going from 602 to 692 from 5400 to 5600..........
[Re: BigFish69]
#2063131
04/28/16 12:32 AM
04/28/16 12:32 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
LaRoy Do you have any pics of the plenum with the modified brows Sorry, no pictures. We kept the same brow shape, just rounded any sharp edges.
[Re: LaRoy Engines]
#2064636
04/30/16 12:30 PM
04/30/16 12:30 PM
BradH
OK, the topic caught my interest enough that I went digging around on our old 'puter to find this info & pics.
Basic combination: 440 + .060"; 10.7 cr, MP Stage VI heads (~305/235 @ .600"), Comp "XX" solid 266/266 @ .050", .600"/.600" (1.5), 108 + 4, , Street Hemi pan w/ ½” pickup, Hooker 2" Super Comps w/ 3.5" x 18" collector extension, 35 degrees total advance, Valvoline 20w50 racing oil.
Tests: A. Stock Edelbrock Victor intake, BG Gold Claw 825 (1.42" venturi, 1.75" butterfly, downleg booster), 1.5/1.5 rockers B. Added 1" open spacer C. Switched to 1.6 intake rockers D. Switched to plenum-ported Edelbrock Victor w/o spacer
TEST ----- A ------------- B -------------- C ------------- D RPM -- TQ / HP ----- TQ / HP ----- TQ / HP ----- TQ / HP 3500 -- 479 / 319 ---- 485 / 323 ---- 481 / 321 ---- 480 / 320 3600 -- 478 / 327 ---- 484 / 332 ---- 481 / 330 ---- 479 / 329 3700 -- 482 / 340 ---- 482 / 339 ---- 480 / 338 ---- 478 / 337 3800 -- 492 / 356 ---- 488 / 353 ---- 483 / 349 ---- 482 / 349 3900 -- 505 / 375 ---- 501 / 372 ---- 492 / 365 ---- 488 / 363 4000 -- 525 / 400 ---- 518 / 394 ---- 513 / 391 ---- 504 / 384 4100 -- 540 / 421 ---- 534 / 417 ---- 526 / 410 ---- 527 / 412 4200 -- 546 / 437 ---- 544 / 435 ---- 537 / 429 ---- 538 / 430 4300 -- 552 / 452 ---- 554 / 454 ---- 548 / 448 ---- 547 / 448 4400 -- 558 / 468 ---- 555 / 465 ---- 549 / 460 ---- 553 / 464 4500 -- 563 / 483 ---- 563 / 483 ---- 556 / 476 ---- 559 / 479 4600 -- 567 / 496 ---- 559 / 489 ---- 560 / 490 ---- 563 / 493 4700 -- 564 / 505 ---- 564 / 505 ---- 566 / 506 ---- 567 / 507 4800 -- 565 / 517 ---- 565 / 516 ---- 566 / 517 ---- 568 / 519 4900 -- 563 / 525 ---- 565 / 527 ---- 568 / 530 ---- 572 / 534 5000 -- 562 / 535 ---- 565 / 538 ---- 565 / 538 ---- 570 / 543 5100 -- 564 / 548 ---- 564 / 548 ---- 565 / 549 ---- 568 / 551 5200 -- 561 / 555 ---- 561 / 555 ---- 564 / 559 ---- 565 / 559 5300 -- 554 / 559 ---- 561 / 566 ---- 560 / 565 ---- 564 / 570 5400 -- 548 / 564 ---- 555 / 571 ---- 556 / 572 ---- 559 / 575 5500 -- 548 / 574 ---- 549 / 575 ---- 549 / 575 ---- 556 / 582 5600 -- 535 / 570 ---- 540 / 576 ---- 540 / 575 ---- 548 / 585 5700 -- 530 / 575 ---- 535 / 580 ---- 535 / 581 ---- 540 / 586 5800 -- 523 / 577 ---- 525 / 580 ---- 533 / 588 ---- 535 / 591 5900 -- 523 / 587 ---- 521 / 585 ---- 523 / 588 ---- 529 / 595 6000 -- 516 / 589 ---- 518 / 591 ---- 520 / 594 ---- 529 / 605 6100 -- 509 / 592 ---- 512 / 595 ---- 513 / 596 ---- 522 / 607 6200 -- 501 / 591 ---- 509 / 600 ---- 512 / 604 ---- 517 / 611 6300 -- 497 / 596 ---- 500 / 600 ---- 504 / 604 ---- 511 / 613 6400 -- 490 / 598 ---- 496 / 604 ---- 497 / 605 ---- 504 / 614 6500 -- 482 / 597 ---- 485 / 600 ---- 488 / 604 ---- 494 / 612 6600 -- 473 / 594 ---- 473 / 594 ---- 477 / 600 ---- 485 / 610 6700 -- 461 / 588 ---- 463 / 590 ---- 472 / 602 ---- 475 / 606 6800 -- 451 / 583 ---- 455 / 590 ---- 461 / 596 ---- 466 / 604 6900 -- 444 / 583 ---- 449 / 590 ---- 454 / 596 ---- 457 / 600 7000 -- 437 / 582 ---- 442 / 589 ---- 441 / 588 ---- 451 / 601
We did a lot more tests, but these are the ones that highlight the improvements seen in the intake mods (in the plenum only, not even port-matched) pictured below.
[Re: BradH]
#2064645
04/30/16 12:38 PM
04/30/16 12:38 PM
BradH
Test D vs. E is the difference from adding a 1" open spacer on the plenum-ported Victor:
TEST ----- D ------------- E ---- RPM -- TQ / HP ----- TQ / HP - 3500 -- 480 / 320 ---- 481 / 321 3600 -- 479 / 329 ---- 479 / 328 3700 -- 478 / 337 ---- 480 / 338 3800 -- 482 / 349 ---- 482 / 349 3900 -- 488 / 363 ---- 495 / 367 4000 -- 504 / 384 ---- 511 / 389 4100 -- 527 / 412 ---- 531 / 415 4200 -- 538 / 430 ---- 545 / 436 4300 -- 547 / 448 ---- 548 / 449 4400 -- 553 / 464 ---- 559 / 469 4500 -- 559 / 479 ---- 557 / 477 4600 -- 563 / 493 ---- 565 / 495 4700 -- 567 / 507 ---- 564 / 505 4800 -- 568 / 519 ---- 572 / 523 4900 -- 572 / 534 ---- 569 / 530 5000 -- 570 / 543 ---- 573 / 545 5100 -- 568 / 551 ---- 570 / 554 5200 -- 565 / 559 ---- 574 / 569 5300 -- 564 / 570 ---- 569 / 574 5400 -- 559 / 575 ---- 561 / 577 5500 -- 556 / 582 ---- 556 / 582 5600 -- 548 / 585 ---- 551 / 588 5700 -- 540 / 586 ---- 545 / 592 5800 -- 535 / 591 ---- 542 / 599 5900 -- 529 / 595 ---- 533 / 599 6000 -- 529 / 605 ---- 530 / 605 6100 -- 522 / 607 ---- 523 / 607 6200 -- 517 / 611 ---- 518 / 612 6300 -- 511 / 613 ---- 513 / 615 6400 -- 504 / 614 ---- 501 / 611 6500 -- 494 / 612 ---- 495 / 613 6600 -- 485 / 610 ---- 485 / 609 6700 -- 475 / 606 ---- 476 / 608 6800 -- 466 / 604 ---- 475 / 615 6900 -- 457 / 600 ---- 463 / 608 7000 -- 451 / 601 ---- 455 / 607
Oh, "D" using 1.5/1.5 rockers was the setup I had on the car when it ran 10.52 @ 126.5 MPH at 3755#s in full street trim (exhaust to rear bumper, pump 93 E10 blend, DOT drag radials, etc.) because there wasn't enough room under the hood to fit a spacer. I figured that was a 610-ish HP combination.
