Re: Leaking head gasket question
[Re: RapidRobert]
#205982
01/27/09 09:50 PM
01/27/09 09:50 PM
Posts: 20,203 Park Forest, IL
slantzilla
Park Forest, IL
There should not be any oil on that side of the head gasket, but I have seen weirder things. Make sure it's not the valve cover gasket leaking and wicking down. The valve cover looks like it may be leaking toward the rear.
How much oil is the motor using? I would not be overly concerned unless it uses enough that you might run it out.
Re: Leaking head gasket question on a /6 Engine
[Re: 41hemi]
#205984
01/27/09 09:57 PM
01/27/09 09:57 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Valve cover gaskets are cheap, and /'s are notorious for leaking, worth a try.
\'s aren't the only Mopar engine notorious for leaking V/C gskts...
[Re: slantzilla]
#205990
01/27/09 10:48 PM
01/27/09 10:48 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Iasked the same thing. I am not sure if its an intake gasket or Head gasket leaking but...
Well it can't be an intake gasket on a /6 for one thing
Well, techinically no, there is no oil sealed by the gasket. However, I have seen stains like that from leaking exhaust and even intake ports. The exhaust side leaks a mixture of oil/carbon/condensation/unburnt gas and the intake side will leak a mixture of gas/oil/carbon.
Don't be afraid even if it is a head gasket. Changing gaskets on a Slant looks intimidating, but it ain't brain surgery. Biggest thing to do is before you start soak all the manifold nuts with PB Blaster for a few days. It will make life a lot easier.
And have alot of fun when you split the intake and exhaust manifolds. your kids may learn alot of new words.
